More Transmission / Drivetrain Threads
Clutch replacement
  • 6 posts
    • Jan 16, 2018 3:31:10 pm
    So I just replaced my clutch on my 07 tC. It’s got just over 100 miles on it. However now when I drive the car and your giving it gas in 4 and 5th gear only it has a rubbing noise. I’m but when your just cruising I don’t hear it at all. Any ideas on what this could be?
    • Jan 26, 2018 5:16:30 pm
    Welcome to the club. Have you diagnosed the problem yet? Synchros or adjustment?
    • Feb 12, 2018 8:07:19 pm
    Definitely not sincros cause it didn’t do it before. It’s still doing it but I don’t drive it much do to it being winter so I’m gonna adjust it when it warms up
    • Feb 13, 2018 3:50:50 pm
    hmm.. if it wasn't aligned when you put it together it's possible it could make noises.. But I'm also wondering if the rubbing noise you're hearing is coming from the throwout bearing. Do you notice the noise is different if you release or apply the clutch?
    odd that you'd hear it in 4th and 5th.. The clutch has nothing to do with those gears, it's only transferring the engine power to the trans. Regardless of the gear chosen.. keep us posted to what ya find.
    • Feb 20, 2018 10:36:40 am
    No change from throwout bearing. I thought it was that to. But definitely not
    • Feb 25, 2018 8:45:35 pm
    well that wasn't good.. I'm wondering if it could be the pilot bearing in the flywheel. I've had that make whirring noises before in other cars I've had.
  • 6 posts
