More Tech Talk and Help Threads
Upgrading 06 TC Headlights & Tails
  • 2 posts
    • Dec 19, 2017 4:10:49 pm
    • Edited 2 times, last by centurytc on Dec 19, 2017 9:14:55pm.
    So I ordered '09 OEM projector headlights for my 06 tc, and I also found a pair of RS3.0 tail lights.
    I assume neither the headlights nor tail lights will work without different harnesses than the 06 oem? What exactly do I need to hook these up? Are the wiring harnesses out there to acquire?
    I also got a morimoto HID kit...would that take care of the headlights harness or would I still need to find something?
    Edit: Upon further research, it looks as though I should've asked for a 9006 harness with the HID kit instead of H11 (but keep the H11 bulbs and ballast).
    I'm still trying to figure out the tail lights.
    • Dec 27, 2017 11:51:02 am
    i think the later tail light's had different wiring harnesses. I think if you use mcgeorgeparts.com or sparksparts.com you can compare the differences. That's probably what you were finding out. I think it's the sub-harness for the lights, but the main harness is still the same. Sub-harness just makes it faster to plug in the unit on the assembly line.
  • 2 posts
