door ajar indicator stays on
  • 5 posts
    • Oct 18, 2018 1:47:15 am
    Hello fellow Scion tC owners: this morning driving to work I notice in my 2006 tC my door ajar indicator keeps flickering and most times stays on. when I parked I close driver door but if I'm not fast enough to lock it will come on again and wont be able to lock it with remote. but if I close the door and be fast locking it with the control it will lock the car and stays off. I searched in forums but it seems no one had that problem before. any pointer will be appreciated it
    • Nov 13, 2018 7:02:58 am
    Did you figure out the problem? I replaced my door jam switch in my 4runner. I bet that's the problem. Let us know the outcome. It helps teach us newbs
    • Nov 13, 2018 7:32:01 am
    • Edited 1 times, last by sgtrod64 on Nov 13, 2018 7:32:16am.
    Hello yota , for your question kind of. I replaced the driver's side once , was still doing it. replaced the passenger one and was still doing it . (with brand new ones0 I re-replace the driver's againg with the original switch then I had the car running for a few minutes then started working normal up to this date. hopefully its ok now. just keeping watching it. thanks
    • Nov 13, 2018 1:48:58 pm
    hey sarge.. did you replace it with an aftermarket and then re-installed the factory switch? or was it a toyota brand switch the whole time?
    • Nov 14, 2018 2:42:50 am
    good morning . I bought it in Ebay but it has Toyota labels as Switch Assy. Courtesy Lamp- part number 84231-60070. so far so good. I think the system need it to reset itself. after I started the car and leave it running for a few minutes went back to normal.
  • 5 posts
