Changed Header now throwing P0420
  • 2 posts
    • Apr 09, 2018 2:46:44 pm
    • Edited 2 times, last by theRanndom on Apr 09, 2018 2:48:17pm.
    http://i66.tinypic.com/6plvs9.jpg
    Good Evening all. I replaced my header today with the one attached and now my CEL is reading a P0420. I'm thinking I might just need the CEL eleminator to put in it. Just wondering if anyone else has any other solutions if that is not effective.
    • Apr 10, 2018 2:49:41 pm
    It's because your catalytic is missing. That's why you're getting a CEL. the cat that is on the intermediate pipe is just an extra one for Toyota to meet emissions (Catches what the primary/first one does not, etc..)
    The real converter is the one that is connected right off of the stock manifold. The primary o2 sensor is actually an air/fuel ratio sensor. Putting a CEL Eliminator is a bad idea for that location, the ECU (computer) won't know if its settings are correct.
    Doesn't look like you've done any major engine mods that would call for a high flow cat like Magnaflow makes.
    Solution? seriously.. put the factory cat/exhaust manifold back on. Otherwise you're going to run into all sorts of drive-ability issues. Like you're already beginning to experience.
  • 2 posts
