2011 TC manual transmission replacement
  • 2 posts
    • Jul 05, 2018 4:58:16 pm
    It’s nearly impossible to find a new manual transmission for a 2011 tC. I was wondering if there are any other options? I heard somewhere a Camry transmission can work. Does anyone know for sure?
    • Jul 09, 2018 7:39:35 am
    • Edited 1 times, last by injapanonly on Jul 09, 2018 7:40:05am.
    2011 tC REMOVAL
    1. support engine with jack or tower
    2. SUPPORT MANUAL TRANSAXLE ASSEMBLY
    (a) Support the manual transaxle with a transmission jack so that it is stable.
    3. DISCONNECT WIRE HARNESS
    (a) Remove the bolt and transmission wire.
    (b) Disconnect the back-up light switch connector, detach the harness clamp and disconnect the wire harness from the transaxle.
    4. REMOVE CONTROL CABLE BRACKET ASSEMBLY
    (a) Remove the 3 bolts and control cable bracket.
    5. REMOVE MANUAL TRANSAXLE ASSEMBLY
    (a) Remove the 10 bolts and manual transaxle.
    NOTICE:
    To prevent damage to the knock pins, do not pry between the transaxle and engine.
    6. REMOVE FRONT ENGINE MOUNTING BRACKET
    (a) Remove the 3 bolts and front engine mounting bracket.
    7. REMOVE ENGINE MOUNTING BRACKET LH
    (a) Remove the 4 bolts and engine mounting bracket LH.
    8. REMOVE REAR ENGINE MOUNTING BRACKET
    (a) Remove the 4 bolts and rear engine mounting bracket.
    9. REMOVE CLUTCH ACCUMULATOR ASSEMBLY
    2011 MY tC [08/2010 - ]; CLUTCH: CLUTCH ACCUMULATOR: REMOVAL
    10. REMOVE CLUTCH RELEASE BLEEDER SUB-ASSEMBLY 2011 MY tC [08/2010 - ]; CLUTCH: CLUTCH UNIT: REMOVAL+
    11. REMOVE CLUTCH RELEASE WITH BEARING CYLINDER ASSEMBLY 2011 MY tC [08/2010 - ]; CLUTCH: CLUTCH UNIT: REMOVAL+
    12. REMOVE WIRE HARNESS CLAMP BRACKET
    (a) Remove the bolt and wire harness clamp bracket.
    13. REMOVE SPEEDOMETER DRIVEN HOLE COVER SUB-ASSEMBLY
    (a) Remove the bolt and speedometer driven hole sub-assembly cover from the transaxle
  • 2 posts
