Site DoS
More Issues and Feature Requests Threads
Cabin filter
  • 4 posts
    • Jul 23, 2018 9:51:45 am
    I have a 2007 TC Scion. I saw there is a compartment for a cabin filter but it is empty. I called the local toyota dealership and they have no listing for one. Do I need one?
    • Jul 23, 2018 11:55:44 am
    hey lori, welcome back, long time no post! Well to get to your question, yes the 07 tC DOES have a slot for the cabin air filter. The reason Toyota left it out is because they did not use a blower fan that was strong enough to overcome the air resistance if a cabin air filter was used. I think it was 09 they updated the factory part to be more powerful.
    What does this mean for you? Put a cabin air filter in but be aware that you'll have a slightly less flow of air out of the vents. Some people notice, some don't. Toyota doesn't have a listing for that filter because they knew that if they restricted the air it could put a load on the blower fan and eventually would cause it to wear out. Plus they wanted a certain amount of air to flow over the a/c evaporator coil behind the dash.. They didn't want the warranty issues associated with that, so they left out the filter.
    Notice that the filter holder *IS* there?! See the engineers did plan on it being there, but the bean-counters/accountants cheapened it up by going with a less powerful blower motor.
    The solution is if you want a filter, get a denso filter online (I personally like these) or another source, you'll eventually learn the cheap junk from the good stuff just by looking at it. Either way.. get a cabin air filter, put it in, run it, see if there is a reduction of air flow.. If there is, see how long you can run the motor before it dies.
    My original fan (without a cabin air filter) died and toyota wanted like $160-200, no thanks. I got a TYC aftermarket blower fan for about $35-40, installed it, had better air flow with a cabin air filter, than the original w/out a filter!
    My solution to this is simple, replace the hvac blower fan with the TYC, then install a new cabin air filter. I say this, that way you don't have to put up with lower air flow from the original blower fan.
    Here's a link to what I bought.. yes sometimes things die (when you read some of the reviews), the TYC has a lifetime warranty on it, if it dies, you get another one for free! I did get one that made some noise, got another been working perfectly ever since.
    https://www.amazon.com/TY...nt-Assembly/dp/B000GOG3MO
    See? I know I'm a bit in-depth but hey now you know.. I'd say get a filter and see how it goes, if the blower fan does die, TYC has a nice quality unit for cheap to replace yours! and yes it's VERY simple to replace!
    • Jul 23, 2018 2:06:22 pm
    Thank you very much. I am going to buy buy one. All of my other vehicles have a cabin filter.
    I was just puzzled when I saw the compartment empty. Thanks again for your help.
    • Jul 31, 2018 1:05:17 pm
    hey lori!! You're welcome for the help, by now you probably got a cabin air filter.. How's it working for you?
Tags: cabin filter
  • 4 posts
