Motul 300 Transmission Fluid
  • 5 posts
    • Jan 04, 2009 1:44:27 pm
    Does anyone use this transmission fluid? Ive heard good things about redline mt-90, but my friend said the Motul 300 is much better. Heres a link. If anyone has experience with it, let me know, thanks.
    http://www.dezod.com/pd-m...ic-ester-fluid-105-qt.cfm
    • Jan 04, 2009 2:27:30 pm
    Never used it but if it's like their brake fluid, it should be good stuff. ~20$ a bottle is gonna set you back 60$ every 30K miles (which isn't bad in the long run) so that may be something to consider. But, if it's good stuff, then it's worth it. I may be switching to the Royal Purple gear fluid soon b/c it worked great for my engine (b/c I have high mileage) so anything else to help the gears out as well.
    • Jan 04, 2009 2:51:47 pm
    ^ true. i think if its good stuff its worth the extra money. im wondering if itll be overkill though, since im stock and it says its for high performance vehicles. ill also look into royal purple though.
    thanks web
    • Jan 04, 2009 3:18:59 pm
    Even if you're stock, it's the formulation of the fluid that matters. If it has a great deal of antiwear agents in it, then that's just an added benefit for you in the long run.
    • Jan 04, 2009 3:28:53 pm
    alright cool ill look into them
  • 5 posts
