Scion tC Light Bulb Sizes
  • 57 posts
  • Page 1 of 3
  • 2
  • 3
    • Jan 02, 2008 11:37:06 am
    The information in this thread will be updated as more information is available, but in the meantime this should be helpful to those that need a quick reference.
    First up.... bulbs for the low beams
    9006---for normal driving---05-07 low beams and OEM Foglight
    an easy way to point out the 9006 is the thin bit of metal coating on the tip... it should also say "9006" there are only two metal prongs.
    High Beams----for spotting those deer----9005
    9005 High beam bulbs burn brighter and usually do not contain the metal at the tip of the bulb. It also has two metal prongs, but will not fit a 9006 female plug unless the plastic is modified.
    Projector Headlamps (2008 + tC + xB----H11)
    New tC's and xB's which feature projector housing and lenses use an H11 size bulb, this size will also need to be specified when ordering HID for your newer model car. Other aftermarket headlamp housing my use a different size H bulb, be sure and check. The OEM projector from Scion uses an H11
    OEM Fog Lights for 2008 will use H11
    7440 Turn Blinker Bulb-----use your turn signals!
    The bulb can be replaced with other colors but it's illegal in all 50 states to use a non amber bulb (when illuminated) Use amber
    7443 Brake Bulb
    Notice the difference from the turn signal. These bulbs have two filaments in them.
    921---Your reverse lights
    reverse lights... nuff said.
    194/168----Most of the bulbs in the interior, parking, domes, side markers and license plate
    They are called 194 or 168 because they are both the same thing. These tiny bulbs are polarized (like most of the bulbs above) meaning you must use the correct + or - or it will not light up. These are also the parking lights used for the 2008 Scion tC.
    Interior Rear Dome----3175 (10mm x 31mm)--called a Festoon type
    Trunk/Luggage Light---3022 (08mm x 28 mm) Festoon
    the easiest bulb to replace, just snap into place.
    Center Cubby Hole---74
    it's a smaller bulb, it comes in normal incandescent or LED
    Speedo gauge/HVAC LED/steering wheel controls/Window switches---PLCC LEDS
    tiny little LEDS that must be soldered into place
    OEM Radio----0603 /window switches LEDs: 1206
    for OEM Radio/Window Switches
    Mirror Signals 5mm SuperFlux
    these LEDs must be soldered into place to replace the OEM LED.
    special thanks to:
    08FastTC
    [user]SquallLHeart[/user]
    for providing additional bulb information
    last updated---05/16/2008---7:52 central----added 7443 brake bulb
    • Jan 02, 2008 12:17:11 pm
    Man you beat me to it. Nice write up
    • Jan 02, 2008 12:49:41 pm
    H11 For lowbeams 2008 tc and xb
    • Jan 02, 2008 1:00:33 pm
    ^thanks, I'm going to add that
    • Jan 02, 2008 1:39:05 pm
    Cubby LED: 74 Wedge bulb
    Auto Shifter LED: 74 Wedge Bulb
    (#74 LED bulb)
    Rear Dome LED: 3022
    For those DIY LED swappers
    Mirror Signal LEDs: 5mm Superflux
    Speedo gauge/HVAC LED/steering wheel controls/Window switches: PLCC LEDs
    Size Comparison between PLCC and 0603:
    last updated: 01/25/08----08:50 central
    • Jan 02, 2008 2:01:49 pm
    Rear Dome LED: 3022
    edit: for those DIY LED swappers
    Speedo gauge/HVAC LED: PLCC LEDs
    OEM Radio LEDs: 0603
    Awesomeness! I'll add this with pics later too!
    • Jan 02, 2008 2:10:08 pm
    ^^ yah sorry i was going to add pics but i'm at work and my boss just dropped off a bunch of things for me to do lol. if i have a chance i'll edit them in for you
    edit: eh i just did them for you Orin lol
    • Jan 02, 2008 2:24:24 pm
    Great write up Orin, this will definetely be one of the most usefull treads ever created, i have lost count as to how many members i have seen asked what bulb for this, what bulb for that..this should definetely be stickied
    • Jan 02, 2008 2:29:04 pm
    you might want to add that the steering wheel radio controls and the door lock lights also take PLCC -2 LEDs
    • Jan 02, 2008 2:36:53 pm
    ^^ oh yah good call. window leds are 0603 though but the plcc-2 will fit lol
    • Jan 02, 2008 4:43:56 pm
    thank you very much, I've added the updated information!
    • Jan 03, 2008 8:38:27 pm
    you guys should put the brightest bulbs that there are for each set. And where everyone should buy them,superbrightleds,onzium(spelled it wrong I think,sorry)etc.
    • Jan 03, 2008 9:35:53 pm
    what about the factory oem foglights? do you have information on those bulbs by any chance? thanks in advance
    • Jan 03, 2008 10:14:23 pm
    Your factory bulb size for your foglights is H3s ...
    • Jan 03, 2008 10:29:27 pm
    thanks bro!
    • Jan 04, 2008 5:34:13 am
    the low beam i saw fasttc post its h11 for 08' is it the same for 07?
    • Jan 04, 2008 5:43:57 am
    You bring up a good point... on 07 and prior the factory OEM fogs are 9006. On the 2008 + it is most likely an H11.
    If anyone can confirm this, I'll update the information
    • Jan 04, 2008 6:28:28 am
    so for the 07 and prior its defintly 9006 for lows and oem fogs,
    HB4 Halogens.
    • Jan 04, 2008 7:32:14 am
    There is this link I posted last year thats been stickied which doesn't have pics but is great for all your tC info: http://home.cfl.rr.com/icdedppl/faq.html#c The Scion tC FAQ Site
    • Jan 04, 2008 7:36:50 am
    ^ That is some useful information, but it's not updated for 2008 Projectors.
  • 57 posts
  • Page 1 of 3
  • 2
  • 3
