Complete TC Wiring Diagram
  • 10 posts
    • Jul 03, 2006 12:43:01 am
    Radio Wiring Diagram:
    For adding on line out converters (for amps on factory radios), hardwiring radar detectors or satellite radios, rewiring a headunit, etc.
    12V Constant - blue
    Ground - brown
    Ignition - gray
    Illumination - green
    Power Antenna - orange
    LF Speaker (+) - pink, (-) - purple
    RF Speaker (+) - light green, (-) - blue
    LR Speaker (+) - brown, (-) - yellow
    RR Speaker (+) - red, (-) - white
    Wiring Diagram for Alarms/ Remote Starts:
    For installing an alarm, keyless entry, remote starter or hardwiring miscellaneous things.
    12V Constant - red or white (ignition harness)
    Starter - black (ignition harness)
    Second Starter - green (ignition harness)
    Ignition - blue (ignition harness)
    Second Ignition - yellow (ignition harness)
    Power Lock - green to blue (driver's kick panel, 20 pin plug) (use a mutlimeter to test this wire with the driver's door key cyliner)
    Power Unlock - purple to pink (driver's kick panel, 20 pin plug) (double pulse, use a mutlimeter to test this wire with the driver's door key cyliner)
    Parking Lights (+) - brown (top of fuse box, 30 pin plug)
    Parking Lights (-) - brown (headlight switch)
    Door Trigger (-) - orange (driver) and blue (passenger) (top of fuse box for both wires, diode isolate each)
    Domelight Supervision - blue (left side of fuse box)
    Trunk Trigger - purple (top of fuse box)
    Trunk Release - orange (driver's kick, panel gray 12 pin plug)
    Brake Wire - blue (brake pedal switch)
    Parking Brake Wire - black (parking brake switch)
    Tachometer - black (data link plug, or at the top plug of the ECM)
    I'm a car technician at an auto shop so if u have ne questions about installs or wiring anything up, let me know n i'll be glad to help u out.
    • Jul 04, 2006 1:23:20 am
    great and useful thread... thank you
    • Jul 04, 2006 10:09:56 pm
    thanks i hope this was helpful
    • Jul 24, 2006 12:14:56 pm
    Does anyone know the subwoofer colors? Or are they wired with aftermarket speaker wires at the dealership?
    • Oct 15, 2006 3:40:01 pm
    my door wiring got mixed up. Out of the 40 wires, there are about 8 that have a twin. For instance 2 pink wires with purple dots... so how do i know which wire connects to which wire.
    • Oct 18, 2006 3:10:56 am
    Take a battery, and watch wich way the cone on the speaker goes. If it goes away from the basket, then the wire that's connected to the + end of the battery is +. If it goes twords the basket, then the wire that's connected to the + end of the battery is -.
    • Oct 19, 2006 8:35:03 pm
    the sub as in the bazooka one?? it has its own harness that your supposed to get along with the sub
    • Nov 19, 2006 7:41:22 pm
    If you tap into a rear speaker's wires for sub only amplification, will it diminish the output for that rear speaker? I dont really want to amplify all of the speakers, I just want the sub to work.
    • May 24, 2011 3:35:42 pm
    Do you have access to the security/remote start diagram for the 2011 Scion Tc?
    • May 24, 2011 3:41:10 pm
    this is an OLD thread i doubt the op is still on this site
  • 10 posts
