Various Component Torque Specs
  • 6 posts
    • May 15, 2008 1:31:05 pm
    I did a search for torque specs since I couldn't find a thread on here with the info. Please add to it for everyone to use!
    Lug Nuts : 76
    Front Struts : center lock nut - 35
    top mount - 38
    bottom mount - 177
    Front Stabalizer Bar : 55
    Rear Shocks : center lock nut - 41
    top mount - 59
    bottom mount - 103
    Rear Sway Bar : 32
    Exhaust : 32 (every bolt from the manifold back is 32)
    Clutch : clutch cover assembly - 14
    release fork - 35
    transaxle assembly - 'A' bolts - 47
    'B' bolts - 34
    'C' bolts - 32
    Hood : mounting brackets - 10
    front catch - 62 in lbf
    • May 15, 2008 1:39:27 pm
    Moved from DIY to Scion tC Discussion
    • May 25, 2010 3:07:17 pm
    Bumping this because I'm adding onto it.
    Part Tightened ..... ft-lbf
    Spark plug x Cylinder head..... 14
    Front wheel ..... 76
    Engine hanger No. 1 x Cylinder head ..... 28
    Engine hanger No. 2 x Cylinder head ..... 28
    Radio setting condenser x Cylinder head ..... 7
    Water bypass pipe No. 1 x Cylinder block ..... 80 in lbf
    Drive shaft bearing bracket x Cylinder block ..... 47
    Drive shaft bearing bracket x Stiffening crankcase..... 47
    Engine mounting insulator RR x Engine mounting bracket..... 64
    Engine mounting insulator FR x Engine mounting bracket FR ..... 38
    Engine mounting insulator LH x Engine mounting bracket LH ..... 64
    Engine mounting insulator RH x Timing chain cover ..... 38
    Engine mounting member x Body ..... 33
    Battery carrier x Body ..... 9
    Air cleaner case x Body ..... 44 in.lbf
    Balanceshaft housing x Stiffening crankcase ..... 1st step 16ft.lbf 2nd turn 90 degrees
    Stiffening crankcase x Cylinder block 24
    w/ head taper screw plug No. 1 x Cylinder block..... 19
    Oil control valve filter x Cylinder block ..... 22
    Cylinder block water drain #### x Stiffening crankcase assy ..... 18
    Cylinder head x Cylinder block ..... 1st step 58ft.lbf 2nd turn 90 degrees
    Camshaft timing oil control valve x Cylinder head..... 80 in.lbf
    Camshaft timing gear x Camshaft..... 40
    Camshaft timing gear or sprocket x No. 2 Camshaft ..... 40
    Camshaft bearing cap No. 1 x Cylinder head ..... 22
    Camshaft bearing cap No. 2 x Cylinder head ..... 22
    Camshaft bearing cap No. 3 x Cylinder head ..... 80 in.lbf
    Oil pump x Stiffening crankcase ..... 14
    Chain tensioner plate x Stiffening crankcase ..... 9
    Oil pump drive shaft gear x Oil pump ..... 22
    Chain vibration damper No. 1 x Cylinder head ..... 80 in.lbf
    Chain vibration damper No. 1 x Cylinder block ..... 80 in.lbf
    Chain tensioner slipper x Cylinder block ..... 14
    Timing chain guide x Crankshaft bearing cap No. 1 ..... 80 in.lbf
    Chain tensioner assy No. 1 x Timing chain cover ..... 80 in.lbf
    Crankshaft pulley x Crankshaft ..... 133
    Oil pan x Stiffening crankcase ..... 80 in.lbf
    Oil pan drain plug x Oil pan ..... 30
    Water pump assy x Cylinder block ..... 80 in.lbf
    Water pump pulley x Water pump assy ..... 19
    Crankshaft position sensor x Timing chain cover..... 80 in.lbf
    Camshaft position sensor x Cylinder head ..... 80 in.lbf
    Oil filter union x Stiffening crankcase ..... 22
    Oil filter x Oil filter union ..... 10
    Ventilation valve x Cylinder head cover ..... 14
    ribbed belt tensioner x Timing chain cover ..... 44
    Engine mounting insulator RH x Body ..... 38
    Vane pump oil reservoir bracket x Body ..... 69 in. lbf
    Return tube x Body ..... 69 in. lbf
    Radiator reserve tank assy x Body ..... 44 in.lbf
    Engine cover No. 1 x Cylinder head cover ..... 62 in. lbf
    Exhaust manifold converter x Cylinder head ..... 27
    Exhaust manifold heat insulator No. 1 x Exhaust manifold converter ..... 9 ft.lbf
    Manifold stay No. 2 x Exhaust manifold converter ..... 32
    Manifold stay No. 2 x Stiffening crankcase ..... 32
    Manifold stay x Exhaust manifold converter ..... 32
    Manifold stay x Stiffening crankcase ..... 32
    Oil level gage guide x Water by−pass pipe No. 1 ..... 80 in.lbf
    Drive plate & ring gear (A/T) x Crankshaft ..... 72
    Flywheel sub−assy (M/T) x Crankshaft..... 96
    Connecting rod cap x Connecting rod ..... 1st step 18ft.lbf 2nd Turn 90 degrees
    Crankshaft bearing cap x Cylinder block ...... 1st step 15ft.lbf 2nd 30ft.lbf 3rd turn 90 degrees
    • May 25, 2010 3:54:35 pm
    Thanks for the contribution
    ~Moved to Maintenance/Repair
    • May 25, 2010 4:23:03 pm
    Np
  • 6 posts
