CLUTCH PROBLEMS!!
  • 4 posts
    • Mar 04, 2010 7:32:15 pm
    help me out guys i turned on my tc and when i reached for the clutch the clutch was all the way down in the floor board? what does this mean everytime i push it in it gets sucked back down...
    • Mar 04, 2010 7:38:48 pm
    A leak in the slave cylinder? Master Cylinder? or Brake fluid reservoir? Check for a leak...if no leak, bleed the slave cylinder. When you pull it back out, does it get stuck back on the floor when you step on it?
    • Mar 04, 2010 7:40:34 pm
    jawsidmtc has good suggestions as to what it may be, if you have no idea what he's talking about, then take it to the shop.
    • Mar 04, 2010 7:42:24 pm
    may have air in the line so try bleeding the line
  • 4 posts
