DIY: Header and Antifouler install
  • 21 posts
  • Page 1 of 2
  • 2
    • Nov 15, 2006 12:44:44 pm
    Sorry, but had to pull it from SL. I followed this one when I did mine and had no problems.
    Header and Antifouler DIY
    • May 08, 2007 11:15:15 am
    Place comments in this thread rather than the SL thread if you have any questions.
    • May 08, 2007 11:21:04 am
    nice thanks for the link!! but which bolt was the hardest he said?? didnt look that hard to me just bolt-ons!! also i ordered an anti foul for the s pipe hopefully it will work (ebay) but he didint mention if you leave or take off the bracket on the bottom holding the stock header to the new header....but nice write up doing mine this week!! has anyone seen any good improvement from this mod using stock exhaust?
    anyone care to help me do mine (houston)
    • May 08, 2007 11:24:09 am
    The tricky bolt is on the manifold all the way left......it's just cramped. Use a 12mm box wrench and tap it with a hammer . The bottom brackets are only left on if the header itself uses them. But, you can leave them there if you want, but they won't be doing much.
    What header you get? I'm in MD but i'd help.
    • May 08, 2007 11:25:50 am
    lol only if u was in houston,tx ill pay u just for a little help to make things easier lol but i got a megan header if i leave the bracket off will the pipe be shaking? lol any improvements with this you think? im using stock piping
    • May 08, 2007 11:27:38 am
    The megan header has the bottom mounts to bolt to the stock brackets.......I'd use them if you don't have an engine damper....they keep the header from cracking with excess engine movement.
    The Megan header will improve your low to mid HP/tq range but be somewhat choking in top end. You'll enjoy your 2nd, 3rd and 4th gear though
    • May 08, 2007 11:31:16 am
    oooh sounds good well help then j/k lol wat else is a good mod to do? i have a CAI already lol and i wanna be a sleeper lol and also im lookin for exterior parts for cheap lol
    • May 08, 2007 11:32:34 am
    Check the profiles around the site............we all have our own style and desires for our car so check the cars out and ask around. I've got mine with sleeper style so check the parts out....there's others on here too
    • May 08, 2007 11:35:55 am
    ooh u selling anything yet? any chance u know if they have a tx sicon club?
    • May 08, 2007 11:40:07 am
    I'm not selling anything...haha.............just to give you ideas ..
    Check the "sponsors" forum on here.....they should have chapters all over the states for certain clubs.
    • May 08, 2007 11:43:05 am
    koo koo i guess we the only one talking on this forum
    • May 08, 2007 11:45:06 am
    Just on this thread, yeah.............check out the site though......I'm sure you'll love it. Lots of information and lots of friendly people willing to help.
    • Apr 26, 2008 5:47:25 pm
    hey, anybody have issues with the spring loaded bolts under the car? i have soaked them countless times in wd40 and barely got one out. the other completely REFUSES to budge.
    • Apr 26, 2008 8:15:58 pm
    Nah, those came out quick and easy for me. I used my impact gun to put them back in so they are really tight but taking them out I used hand tools. If you have access to an impact gun, I highly recommend using it before you round the bolt off if you slip.
    • Aug 13, 2008 7:53:23 pm
    WD-40 works fine, but if you want real results use penetrating oil. Works much faster and is just generally better at the job than WD.
    Also, when i was a mechanic as a rule of thumb we always installed any exhaust bolts with some anti seize on them. That way if in the future you gotta work here again, you'll thank yourself.
    As far as spring loaded bolts being a pain to get off - they are often just that. Hose em down with penetrating oil, wait a few minutes, and get after it with an air ratchet if you have one, if not just go to town with hand tools.
    • Aug 13, 2008 8:37:44 pm
    Never Seize on every exhaust bolt, every time FTMFW!!!
    • Aug 14, 2008 1:30:53 am
    word.
    • Aug 25, 2008 11:06:50 pm
    k i got a pretty stupid question but when u say disconnect the negative battery terminal after installin the antifouler, i was told by my autos teacher to never disconect the battery terminals because it will set off the airbags. idk if i misunderstood this or misunderstood wat u said, can u clear things up please.
    • Aug 26, 2008 8:13:49 am
    Must have misunderstood. It won't set off the airbags b/c it's not a detonation signal to the "brain" for the airbags. Disconnecting the negative is the safest way to take all power away from all sensors and resistors in the vehicle.
    • Feb 20, 2009 5:31:35 pm
    Biggest problem I had when installing my header was my 02 sensor bolt, I had to take it to ptuning to get them to do try & take it off & not even they could get it off so I had to spend another 140 bucks(Love ptuning discount) & get a new 02 sensor from a dealership. The only good thing about it is that I've got a 02 sensor on my stock header & on my DC sports header so its an easy swap for emissions
  • 21 posts
  • Page 1 of 2
  • 2
