| LOUD Computer Hum Noise....Grr |
| Anyone have a pic of the VSV mounted? |
| Sound Insulation Noise Reduction |
| EBC Rotors: Make Noise?? |
| screeching noise.. |
Vango
anyone have this noise issue? just installed a TRD CAI and the vsv is making a loud CLICK-ing sound. dealer and other Tc owners say this is normal. thing is, i had an Ingen CAI installed before replacing it with the TRD CAI and no noise was heard with the Ingen CAI. i have never heard of this noise before on any of my friends' cars with intakes. is it just me? - Vango Tc |
I have the TRD and I don’t have any noise issue with it. Mine sounds like a regular CAI. 2008 G37 OB Sport 6MT... 2007 335I 4DR... |
exiled622
can i ask why you switched from injen to trd? |
Vango
sad truth is i got in a front end crash and my insurance gave my repair shop $350 to replace the damaged Ingen CAI, which i got for only $140, so why not spend it all on a TRD CAI retailing at $450 on sale for $340. and here i am. still wondering if anyone has has this issue. it can't be right, even if the damn dealer says so. - Vango Tc |
I have this noise on my K&N intake. I had it even on my stock setup. It's just a vacuum going into the valve. Nothing to worry about. It depends on how much vacuum the intake is pulling. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
tick.. tick tick tick tick.. tick tick... yeah.. it's normal. LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
aDelcoTc
now wait....i have the "tick tick tick tick tick tick tick....." i thought this was valve tap or at least something coming from the head. i don't think this is the same noise as the "intake sound" the op is describing... am i wrong? OP- when do u hear the noise, and specifically what does it sound like, aka. what do u think it might be? Scion tc: Its essentially a 2 door Camry that spins up the tires quicker..... |
Nah, the valve tap is normal for our engine as well......just the way it's designed. On the intake, that black vacuum sensor that attached to the main tubing closest to the driver's strut tower is what he was describing. That makes a tick/taping sounds as well and just sound like a little BB in a 35mm film canister. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
aDelcoTc
okay, NOW i think i know what you are talking about. i used to hear that sound, it drove me crazy. i stuffed a wristband in there and it seemed to go away. but i think it has come back recently... so its kindof more related to engine vibration than air intake flow, right? Scion tc: Its essentially a 2 door Camry that spins up the tires quicker..... |
Well, it's a vacuum sensor so it's related to the vacuum effect of the intake. It's nothing to worry about though. I believe there's a vacuum line that runs off the TB into it and that's where it gets that pulsating tap. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
2006TcScion
i have the trd and it sounds fine for me. Want These icons pm me and i will make you one ![]() ![]() -Released Day ![]() ![]() ![]() ![]() ![]() Live radio is now up and running http://radio.skaterstuff.com:8000/listen.pls |
Vango
ok guys. . . i solved it. turns out the dealer tech who installed my TRD CAI, purchase and install at a discount, left the flange loose. i tightened it and the loud clicking is gone. the sensor still ticks as it should, but at a level i can live with. it's quite in the cabin once again and the noise i only hear is the roar coming out of my TRD CAI. yipee! thanx to all that helped out. - Vango tC |
Triniosito
i Would Of Stuck Wit injen ![]() |
