| Lowering Springs on my tC for your stock springs! |
| Tsudo full exhaust setup |
| Pros and cons of lowering spring?? |
| Georgia Tsudo Full Exhaust |
| FREE Tsudo Axleback |
Juss_tC
Hi guys, i was wondering if there is any way i can push down my muffler, because it is like fuckin touching my bumper (scraped it and my car is BRAND NEW!). And do they make heat shields for Scion tC's if so, can someone give me a link to it. Thanks. |
moved to exhaust forum* |
Common problem with Tsudo/Skunk 2/Tanabe (not the newer version I believe)......The bracket that holds the canister up can be "manipulated" a bit. You'll need a torch and some pliers, but heat the bracket up a bit and bend it until the tip is about 1/2 inch away from the bumper. If you don't want to do that, take it to a custom exhaust shop (not Midas/Meinekee or some place like that) and have them do it. Probably about 25$ but whatever. With canister style exhausts and exhausts that don't have a flared tip (one that fold back on itself leaving a space between the pipe and the out edge of the tip), you'll want 1/2" distance from the bumper at a MINIMUM. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
