Home > Performance Mods > Intakes > Sea Foam
Sea Foam
aDelcoTc
Oreland
Pennsylvania, US
anyone ever use it? i guess apparently its used as a throttle body/intake manifold cleaner. helps break up deposits and stuff...idk..
just saw a vid on streetfire of a guy who used it in his eclipse gs, and his exhaust was blowing tons of white smoke for a while....
[#] Mar 15, 2007 02:00pm
Never used it but used to sell lots of it.....lots of older engines used it to clean excess carbon build up and yeah, it'll make you smoke a shit load.
[#] Mar 15, 2007 02:02pm
aDelcoTc
Oreland
Pennsylvania, US
so i guess it makes sense if you have a carb, but for modern direct injection engines, is it really necessary. or even worth it?
i mean, how would u get any deposits or build up in your throttle body or intake manifold if you are spraying fuel directly into the cylinder??? hmmmm...not sure about this one..
[#] Mar 15, 2007 02:06pm
Nah, not really..........Periodically, if you want (i used to in my truck), get the black bottle of Chevron Techron. That works great. But honestly, for our engines, not really necessary. Wait until you're over 120K or something
[#] Mar 15, 2007 02:10pm
TOP: Home > Performance Mods > Intakes > Sea Foam
