Home > Performance Mods > Exhaust > help me out someone
help me out someone
djethnix
Baldwin Park
alright so i went to the muffler shop yesterday, and i wanted to add another resonator.. and the guy said that its gonna hang low.. and then he lifted the car to get a better look.. and then he said theres no room for another one... i dunno wuts going on.. i have a stock mid pipe.. i dunno if thas tha case.. but if anyone can help me out.. does anyone have a picture of their mid pipe with 2 resonators.. or wut should i do... thanks..
[#] Mar 15, 2007 06:43am
Take it to another shop. I have mine hanging right where the axle back would meet the midpipe and it doesn't hang any lower than the tow hook welded on the rear axle.
[#] Mar 15, 2007 08:38am
soCAL-tc
Los Angeles
i have a muffler shop in el monte that will do whatever you want, whenever you want, no questions asked...pm me dude if you're interested i'll give you directions, i wanted to do something with the 3 series so let me know and maybe we'll get some discount or something, i also want another resonator too, but unfortunately i have a megan mid-pipe so i don't know where i'm gonna put it...
[#] Mar 15, 2007 10:05am
I'll upload pics of mine to show you that my resonator hangs no lower then the bend in my midpipe just before the gas tank. About 4 inches of ground clearance WITH my drop.
[#] Mar 15, 2007 10:09am
  • El Chupacabra
so.. for resonators you'd have to cut up the midpipe and weld the resonator on? :o
The Thread Killah
[#] Mar 15, 2007 10:13am
Yes
[#] Mar 15, 2007 10:14am
The redline is just to show how it's level with the lowest point of the exhaust. **mind the rust b/c it's a solid steel resonator (moroso spiral flow)....I'm sanding and painting it with heat paint when it warms up a bit.
[#] Mar 15, 2007 10:15am
aDelcoTc
Oreland
Pennsylvania, US
but web, u only have 1 resonator right? what midpipe is that too?
[#] Mar 15, 2007 12:11pm
No, I have 2.....It's the Draxas midpipe. It has a highflow CAT and another resonator. Came like that ....I just added the second one there and stiff welded the rear section at the tip and the side support you see in the picture. It flexes very little and with my ETD setup, my exhaust feels much more solid and the tone is nicer.
[#] Mar 15, 2007 12:13pm
aDelcoTc
Oreland
Pennsylvania, US
oh. where is the other resonator? i assume the car is the same location as stock?
[#] Mar 15, 2007 12:18pm
Yeah, it goes:
CAT right at the neck of the mid pipe, then the two little arms where the hangers are and then the resonator. The flange was a few inches past that but I welded the rear solid and it made things much easier. I'm very happy with this setup. FINALLY!....haha
[#] Mar 15, 2007 12:20pm
I'll try to get a pic real quick.
[#] Mar 15, 2007 12:24pm
aDelcoTc
Oreland
Pennsylvania, US
Web wrote:
Yeah, it goes:
i'm not seeing the cat (assuming its not in the picture) or the 2 hanger arms...but oh well.
what exhaust (rear section) do u have. looks to be pretty wide piping. is it 2.75 or 3"?
[#] Mar 15, 2007 12:27pm
No, it's totally custom.
Draxas S pipe
Draxas Mid pipe
Both just under 2.5 inches inner diameter.
Then the moroso spiral flow resonator is same inner.
Piping between resonator and spintech muffler is same and then a 2.5 inch inner diameter exit pipe
[#] Mar 15, 2007 12:31pm
CAT:
Draxas midpipe w/resonator:
Sorry for the blurriness.
[#] Mar 15, 2007 12:36pm
Original thread i had a while ago:
http://www.clubsciontc.co..._id=8127&page=1#76492
Video clip isn't too clear though...lot's of distortion from my little digital
[#] Mar 15, 2007 12:38pm
aDelcoTc
Oreland
Pennsylvania, US
Draxas S pipe
Draxas Mid pipe
OK. i think i got it. so here is your setup:
exhaust manifold>>>Draxas S pipe>>>Draxas Mid pipe w/ hi flow cat>>>>moroso resonator welded between midpipe and >>>>>spintech muffler>>>stock tail/exit pipe. do i have it right?
[#] Mar 15, 2007 12:55pm
the exit pipe is actually off my original draxas rear section. I just tossed it and kept the exit pipe
Plus, HPR header....(draxas mid pipe has resonator also)..the rest is good
[#] Mar 15, 2007 12:58pm
aDelcoTc
Oreland
Pennsylvania, US
where is the resonator in the draxas mid pipe? so then u really do have 2 resonators... 1 cat and 1 muffler..
so, does the draxas S pipe eliminate the stock cat? or is that the mid pipe that does that.
[#] Mar 15, 2007 01:01pm
aDelcoTc wrote:
where is the resonator in the draxas mid pipe? so then u really do have 2 resonators... 1 cat and 1 muffler.. YUP
so, does the draxas S pipe eliminate the stock cat? or is that the mid pipe that does that. spipe doesn't do anything to any of the CATs
The header eliminated the secondary CAT on the manifold and the midpipe replace the stock primary CAT with a highflow.
[#] Mar 15, 2007 01:05pm
djethnix
Baldwin Park
awsome guys thanks.. so right before the mid pipe meets the axel-back.. how many inch resonator should i get.?
[#] Mar 15, 2007 05:17pm
TOP: Home > Performance Mods > Exhaust > help me out someone
