| weapon r torque damper |
| Cleaning Weapon R with injen solution?? |
| Weapon R Header Installed |
| Weapon*R Intake Manifold |
| Question for Weapon R SRI User |
soCAL-tc
does anyone have one, is it worth it, or is it just a grounding kit that is mounted along the ignition brackets...? |
Do not get it. It does nothing and mounting has some issues. There was a thread on SL about it and it is worthless. The engine is grounded pretty damn good stock and a grounding kit helps (minimally...just keeps the lights a bit brighter and the radio static down a hair). The equalizer does nothing for ignition. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Mugetsu
Damn really?.. i really wanted that too but the 100$ price tag was keeping me from buying it. I'd do the ground kit but i think they look so...sloppy...i fig this basically WAS a G kit but just cleaner, kinda made me wonder thought because the coil packs are plastic so how would it ground them... if it was 40 to 50 bucks i'd still get it... when is weapon r gonna get the fraggin hint! wow that was more intense than that one time I forgot how to sit down... |
i've got a ground kit in my engine bay (it's black) and it blends in and you can't see it.............It depends on the type you get though..........some have a center mount on the negative where ALL the wires lead back. There's no need for that. As long as you have all the ground points in sequence and form a complete circuit around the engine bay, it'll ground fine. Mine's by GroundWire I believe. Well, the coils have a plasitc housing but are bolted down by metal. All and all, the plate is worthless. You see no improvement on anything other than a shiny thing in your engine and less money in your wallet. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
SL threads about this: http://www.scionlife.com/...hp?t=149047&highlight thread 1[/url]
http://www.scionlife.com/...hlight=ignition+equalizer
trdmaster_
they break easily |
