Home > Visual / Audio Mods > Exterior Styling > How to adjust your headlights
Reg'd: Apr 17, 2006
THE SHADOW
Use this link (Headlight Adjustment) to learn how to adjust your headlights. This is to adjust the angle of the housing so it works with both HID and stock Halogen bulbs.
[#] Feb 28, 2007 10:04am
aDelcoTc
Reg'd: Jan 25, 2007
that was the most complicated thing i've ever read.
[#] Feb 28, 2007 10:25am
Reg'd: Apr 17, 2006
THE SHADOW
hahahahahaha, I know.....kind of confused me but it's still something to follow......hahahaha
[#] Feb 28, 2007 10:26am
Reg'd: Apr 17, 2006
THE SHADOW
I just aim mine at my garage door and keep my left headlight perfectly level at 90 degrees and I raise my right one up about 2 inches higher than the left. That way, it keeps the light out of people's eyes coming towards you but you have more vision down the road near the shoulder.
[#] Feb 28, 2007 10:29am
brettf3588
Reg'd: Jun 20, 2007
Tech Advisor
WEBSTER, if im not getting as much light on the right side as on the left side, should i rise the right one up??? or is there a way to move it horizontally???
-07BSPtc-
[#] Jul 26, 2007 12:22am
Reg'd: Apr 17, 2006
THE SHADOW
I answered in the other thread.......haha.
What type of bulbs do you have? High wattage halogens?
As I stated in the other thread, if they are not HIDs, then the higher you aim them, the less you will see. B/c they are halogens, they don't have the same travel distance as HID bulbs would and they seem dimmer the further you get.
Adjustment of the headlight can be done by a small silver gear-like screw (8mm I believe) at the bottom of the back side of the headlight housing. There's only an up or down motion to the headlights but they are set on an angle anyways. Up will move them up/right, and down will move them down/left. No horizontal adjustment.
They are designed to show you more of the right side of the road for safety reasons (pedestrians and cars on the side of the road). That's why they have a slight off-to-the-right lean even stock.
[#] Jul 26, 2007 08:10am
brettf3588
Reg'd: Jun 20, 2007
Tech Advisor
aight kool thanks
-07BSPtc-
[#] Jul 26, 2007 10:55am
r6ryda81
Reg'd: Nov 03, 2007
Window Washer
i bought these halo projector headlights off of ebay and when installed them they looked great! the halo's are ccfl, so they are as bright as the sun. downfall, the actuall projector low beam lights point DIRECTLY @ the ground and i cant see anything in front of me! HELP! how do i point them higher?! here is a link so u know what lights im talking about. may help assist in an
ahttp://cgi.ebay.com/ebaym...sspagenameZWDVWnswer.....
[#] Nov 04, 2007 12:44am
TOP: Home > Visual / Audio Mods > Exterior Styling > How to adjust your headlights
