| help, please stereo |
| Misfire or? Help please... |
| Help with my alphasonik subs please |
| Please help my headlights! |
| Need help fast!!! Please |
Has anyone else's auxillary fuse blown? I usually have my phone charger plugged in my arm console all the time but the phone isn't plugged in all the time. The charger is continually on when the car is on so I'm thinking the fuse blew on it. I've tried moving the adapter around but the little light doesn't work. I was just going to change the fuse b/c that's the only thing that does work...I think it's fuse #37 in the diagram. Anyone have this happen to them? ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Nope.. although the fog lights on my friend's tC kept causing his fuses to blow. probably a bad ground.. anyways, how long have you had the charger in your car? ![]() ![]() ![]() The Thread Killah |
30K...haha ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Ok, I checked the fuse and it was fine. Now, I also tried plugging my radar detector and another phone charge cord in the ACC Power slot and nothing. Anyone know what it could be? Maybe I'm checking the wrong fuse? In the manual it's #37 (ACC Power) on the instrument panel fuse panel. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
aDelcoTc
bad wiring, or relay? idk Scion tc: Its essentially a 2 door Camry that spins up the tires quicker..... |
Didn't check if there was a relay for it but i'll do that later.....the wiring is stock and i checked the connection and whether the wire was melted or what...........nothing bad Well, i'll keep looking ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
rrimportracer
i dont think its your acc fuse, there is a lil fuse box under the dash were your left leg goes, i think it was like #15 on there, or something like that its a 15amp fuse, check it out, ill be back later to tell you exact number. I just changed mine cuz when i was doing my alarm i messed with the wires to much and blew that fuse ![]() myspace.com/asphalt_photos check us out!!! |
Ok, thanks...yeah, that's where I found the 15 amp fuse. It's number 37 in the little spot near the clutch pedal. But let me know if it's supposed to be another fuse. Thanks. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
RR, found any other fuse it could be? ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
rrimportracer
no man, all i can say is take volt meter to it and test them, idk man ![]() myspace.com/asphalt_photos check us out!!! |
i have a few diagrams for u web, PM me |
lepa101
Hey guys got a ? I have a 06 and the head unit works and has power and everything but the sound won't come out the speakers. Just wondering if you think it could be a fuse like this guys. |
Is it an aftermarket unit? Make sure they plugged any audio cables back into the back of the radio. There's no seperate fuse for speakers so it seems like something is unplugged. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
lepa101
Its stock HU. Thats what I was thinking was a wire isn't connected i'm going to have a aftermarket HU put in and I am hoping that will do the trick. I want a sub and amp as well just trying to figure out which one I want any ones you recomend. |
hvtopiwala PM him. He's the audio guy ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
lepa101
thanks web |
np ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
OK, NEW PROBLEM! I was attempting to check the fuses under the dash to see if I could get the ACC power outlet working again and crap.....more problems. Now, my moonroof doesn't work, speedo, odometer, tripmeters and I have 3 lights on in my dash: Tire pressure, Brake, ABS Tested the ABS by trying to lock up and they definately vibrated like they should, tested the ebrake by moving forward and slowly engaging it....it works and is fully disengaged after that but the light stays on, the tire pressure light just doesn't go away even after I try to reset it. Nothing registers on the odometer, trip meters or speedo. All of this just stopped working as soon as I pulled a few fuses out and then plugged them back in. The car was off when I pulled them. I tried to reset the ECU with the battery disconnect,....nothing...still the same. Help?! ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
hahahahaha...............NM.............. I pulled a fuse down and instead of putting it straight back up into it's spot, I put it in the spot next to it. All is good. I really am a tard with a capital RE sometimes! ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
rrimportracer
lol i was about to say web your officially screwed, lol jk ![]() myspace.com/asphalt_photos check us out!!! |
