| fog lights on rs4 ? |
| Custom Plug n play zex nitrous kit FS |
| Head&Tail Light Vinyls |
| Wattage on VRD fog lights? |
| need help looking for fog light |
Just keep in mind that the high beams will take about 15-20 seconds to charge up to full potential. I had them on my car and used them as spot lights down LONG country roads. They are GREAT for visibility but the slight downfall is the 15-20 second delay in charge up time. If you pop those babies on early and "accidentally" take out 1-2 cars with it, you'll be fine ![]() Complaining is futile when you supported the victory. |
Crash
If you start the high beams up, then switch to lows, after a while of driving the highs should still be charged as long as the car isnt turned off correct? Even if not, you can hold the light lever back to activate highs and lows for a few seconds to let them charge, then switch. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Nope. If the HIDs stay off for about 1 minute, they need almost a full charge cycle. If you just pull and hold the lever, then they get a full blast of power but even if you do that for 30 seconds and then flick them on normally, they still have a charge cycle of about 10 seconds. It helps only slightly....believe me, I tried them multiple times to cut that time down but it's still about the same. But what you DON'T want to do, also, is continually turn the HIDs on/off. The ballast will overheat or have internal damage caused to it by the current spike. That's why if you have HIDs, you never turn them on and off in short time intervals. ![]() Complaining is futile when you supported the victory. |
h2oyelnats
quick question. what is the the light that turns on after the first click? after the 2nd click? and when you pull the whole thing towards you (highbeam?)? |
operatic
First click = parking lights / turn signals Second click = low beams Pull back = high beams |
TheFantasticG
Let me tells you guys something about putting 2008 projector headlights with operatic's HiD kit on a 2006 tC.. SEXXEE /postingpictureslater ![]() |
TheFantasticG
SEXY: ![]() |
h2oyelnats
anyone familiar/particular with the brand, HALO? they're not real HIDs i dont think...but pretty close. they're 7500K? because i just got them swapped in for my low and high beams |
I have yet to see another lighting product that's "almost" like HIDs.. ![]() ![]() ![]() The Thread Killah |
operatic
Oh that is sectsee
I cannot find the brand Halo in terms of regular light bulbs. But my first guess is that it is a halogen bulb with a tinted glass. So in the end your old halogens would be better. |
operatic
up for some HIDs! |
operatic
up for some HIDs! |
operatic
bump |
misternguyen
few questions... 1) whats advantage of a 50w ballast? 2) who has both high and lows? is it too much? because thats like.. 4 ballasts 3) if i want a clean install where can i put the ballasts at? |
Spitfire
i ask operatic about having them on high beams as well he said its possible but don't qoute me on that.lol. -wayne 08' BRM tC A monkey in a suit is still just a monkey... |
operatic
1) They are brighter than 35w ballast, that is the only advantage 2) 3) I know a lot of people put them behind the front bumper, but I have seen a few people put them in front of the radiator support (without having to take off the bumper) for a super clean and easier install
Yes, it is very possible |
misternguyen
oh thanks operatic i want super bright lights.. thats why im going to get high beams too.. yeah im that ass on the road hahaha waiting for this weeks check so i can get them.. cant wait |
operatic
It's all good |
operatic
up for the dizzles! |
operatic
TheFantasticG
I installed my ballasts under the headlights themselves... and zip tied them down for additional insurance. Those brackets that come on the ballasts are REALLY flimsy.![]() |
operatic
There not great but they do work |
TheFantasticG
Indeed. They do work. Its actually alittle bit better that they are that way because since there's no set install instructions. So you can bend them to however you need to for mounting. I bent 'em flat to fit them under the headlights.![]() |
operatic
All you gotta do now is enjoy em partner |
TheFantasticG
Turns out, I don't drive much at night. But when I do, I see everything in front of me now. ![]() |
