| Fog Lights Problem!! Help Please! |
| Turbo install? Is it plug and play? |
| multicolor under body and interior light kits? |
| parking lights |
| neon lights |
Reg'd: Dec 08, 2005 |
send a PM to |
operatic
If it is for your 2008 tC in your profile you'll need an H11 kit. Also if you like the purple, we do carry it. Also so you know, the purples will be really bright too |
aznkidlee
Reg'd: Dec 05, 2007 Tire Changer |
Sounds like the relay actually. Reinstall everything loosely and have a friend turn on the low beams while you have your head near the little black box on the relay harness. Listen for a click, if it clicks its fine, if not, its dead. Also check the fuse on the relay harness. Let me know how it goes. I can hear a click sound every time I turn on my low beams. How do I check the fuse on the relay harness? |
leonard
Reg'd: Mar 07, 2008 Tire Changer |
finally took a pic with my hid's 12000k w/ 50w ballast ![]() |
operatic
They are the little square boxes near the relay. The top opens up and you can check the fuse from there. If nothing, check your in car fuses and if still nothing, hit us up, we'll get you back up and running
Looks sweet man |
operatic
up for some HIDs |
operatic
up for some HIDs |
youngflyer
Reg'd: Jul 07, 2007 Scion Guru |
bump cuz im getting paid soon lol! ThE JeWiSh PiMp |
youngflyer
youngflyer
ladiablette
Reg'd: Jul 13, 2008 Tire Changer |
so, im interested in getting some HID's for my tc, but i see people saying 500k, 10000k etc.. what does all of this mean? and are they easy to install (just changing the bulb or the wires as well?) ... are they DOT approved in CA? and do they burn out the original wiring? ... |
operatic
Those 5,000k, 10,000k, etc. Those are kevlin ratings, in short it is just what color the bulb will be when lit. Here is a quick run down of colors 4300k = Crystal White 5000k = In between color 6000k = Crystal Blue 8000k = Blue 10000k = Deeper Blue 12000k = Violet (Deep Blue with a slight hint of purple) The install is pretty easy. For someone who has never done it before, it takes about 30-50 mins. Here is the instruction manual to show you what will need to be done to get everything up and running. www.3bspecialties.com/instructions/3BSpec_HID_Instructions.zip No these are not DOT approved |
wuma
Reg'd: Feb 26, 2007 Tech Advisor |
bump because i owe operatic however much that pizza today cost! thanks to you and dave for installing my springs |
rimjay
Reg'd: Jun 01, 2006 Godlike Advisor |
yo op...judging from the pics in my profile, what kelvin HID would u say my lights are? cause i may look for some new K... |
operatic
Na man its all good, car looks super sexy now with the drop. Time to make a thread about it now
From the pictures they look like 6000k or 8000k. With the 08 projectors, the higher up you go in the kevlin rating the more colorful the cut off line becomes. |
rimjay
ok thx operatic |
operatic
No problem |
Bump for the best kit out there! ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
aznkidlee
operatic I replaced the 20Amp fuse from the little square boxes and it fixed the issue. Apparently, the plastic around the old fuse melted into a small glob and I guess that prevented it from working. Thanks for the help. |
operatic
Glad you are back up and running partner |
operatic
operatic
up for those HIDs! |
sp007
Reg'd: Jun 18, 2008 Detailer |
OK...So I am REALLY pumped because I really want the HID's for my tc, but I have a couple of questions! I own a 2007 Scion tc and the color is midnight blue....I am not quite sure what to get....I was reading the whole thread, but I still need some input/answers: 1. Considering the color of the car, what would look better? the bright white that Web was talking about (I think he said 5,000 K) or the bright white with a hint of blue (That would probably be 6,000 K) 2. Cops seem to like my car for some reason, so I was wondering how bright are the 6,000 K compared to the 5,000K ?....and if the hint of blue is visible enough on the 6,000 K, that could easily get me pulled over because it might resemble the blue light that cops have? 3. I read in this thread some people talking about projector setup. I have no idea what that is! do I need to buy that with my HIDs? 4. I also read about the HID light not lighting/pointing forward ...rather wandering off to the sides/out of angle. Is that true? Would the light wander around??? I don't really understand what happens. 5. If I do decide to get it, would anyone here be willing to hook me up with the installation? I have never done a major installation by myself, and I really don't want to mess anything up.... Thanks in advance for your help! |
1. Considering the color of the car, what would look better? the bright white that Web was talking about (I think he said 5,000 K) or the bright white with a hint of blue (That would probably be 6,000 K) ^matter of personal taste 2. Cops seem to like my car for some reason, so I was wondering how bright are the 6,000 K compared to the 5,000K ?....and if the hint of blue is visible enough on the 6,000 K, that could easily get me pulled over because it might resemble the blue light that cops have? the kelvin rating won't affect the actual output of lumens, although a 6,000 to 5,000 will reflect off objects much better 3. I read in this thread some people talking about projector setup. I have no idea what that is! do I need to buy that with my HIDs? ^just buy the right bulb the to with your model of headlight 4. I also read about the HID light not lighting/pointing forward ...rather wandering off to the sides/out of angle. Is that true? Would the light wander around??? I don't really understand what happens. ^there will be light scatter when using with normal headlamp reflectors 5. If I do decide to get it, would anyone here be willing to hook me up with the installation? I have never done a major installation by myself, and I really don't want to mess anything up.... Thanks in advance for your help! ^everyone will help you out |
oh yeah, and about the cop (color temp question) 6,000 has some blue, but it's tame, you'll be safe. 8,000 k is a little more blue but it still looks like ice. You'll be fine either way. 10,000k might be pressing your luck. |
