| FS: H3 fog light HID BULBS 6000K~~~ |
| FOG-Lights-HID-Converts |
| fog lights on rs4 ? |
| Custom Plug n play zex nitrous kit FS |
operatic
up for some HIDs! |
operatic
Bringin' it up for those Dizzles! |
operatic
up for some HIDs! |
operatic
up for some HIDs!!!! |
operatic
up for some HIDs!! |
keLz
san antonio ? lol kind of far... but half way? om me [kelz] Imma Beast Wid Out Tha Hype! |
operatic
Ya that's kinda far even half way. Sorry partner |
operatic
up for some HIDs!!! |
07sctc
operatic deserves another bump. i still am loving the 6000ks i got from you!! beware of the mad sciontist ! ask me your car audio and electronics questions!! |
Crash
I hope you got some saved back for me Operatic, ordering them in about 3 days! ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
operatic
Thanks partner!
We still got a slew of 9006's in stock, so unless there is a random surge in sales, we got you covered |
RoulettetC
Operatic, girlfriend said super fast shipping! She gave them to me today (6000k) for my birthday. I am trying to put them in this weekend!!! ![]() -Thanks for the sig Aciidsneaker |
SupaDupaWhite
got my kit for my HIDS A COUPLE DAYS AGO.. they are awesome!!! great buy!!! |
Crash
BUMP!!! Just made an order for the 8000k! ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
RoulettetC
God, I can't get the bulb to go in all the way so that they will turn and lock in, what's the deal? The bulb say they are 9006 and that's what my stock low beams are. ![]() -Thanks for the sig Aciidsneaker |
RoulettetC
Crash
Ive heard that if you remove the rubber ring around the light it will go in perfectly or something like that. It should be earlier in this post, read through and you will see how to fix it. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
Crash
Hey man, all you gotta do is call when you have a problem 832-428-3669 names Pat Also as for the plug that goes into the ballast, the tabs should be facing outward (away) from the ballast. Secondly, the plug that goes into your OEM connector, check to see if the black wire on our connector is matching up with the black wire on your OEM connector. If not you'll need to flip it around 180 degrees. Last but not least, if the bulb is not going in, swap the o-rings on the HID bulbs with your old halogen bulbs. This is a response I found from Operatic in another thread. This guy was saying he also had trouble fitting the light into the ballast. Hope you get it figured out. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
This is the most common thing I found with the kits but definitely not complaining b/c it's easy to swap. 9/10 times, this is the fitment issue. Roulette....did you get them in? ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
RoulettetC
Yep, I swapped the o-rings on my own intellect before I checked back. Got all the wiring finished and only one bulb works. After swapping things around and testing and talking to patrick, turns out I have a faulty ballast, so now I won't have HID's until tuesday ![]() -Thanks for the sig Aciidsneaker |
^That sux ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
RoulettetC
Yea, I know it just sucks because this was the first mod I did entirely on my own, especially because electrical stuff intimidates me. And turns out I did well, but it just doesn't seem that way. ![]() -Thanks for the sig Aciidsneaker |
Crash
Its all good man, you will get the new ballast and be rockin the HIdizzles in no time. ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
operatic
Hey we talked over the phone today, sorry about the faulty HID ballast, but we'll get you taken care of in no time so you are up and running the way you are supposed to be!
Awesome! Glad you are enjoying em partner
Thanks for the bump! As for the 8000k's you know what I'm gonna say "You'll be seein' them in no time partner |
Crash
Is there enough room under the hood of the tC to fit 8k ballasts for low beams, another 8k kit with 50w ballasts for high beams, AND a 35w ballast for fogs? Would it all be able to be hidden well? ![]() The SEARCH feature on the site works, I promise. USE IT!!! "I almost numchucked you, you dont even reallise!!" -Will Ferrell- |
