| Fog Lights Problem!! Help Please! |
| Turbo install? Is it plug and play? |
| multicolor under body and interior light kits? |
| parking lights |
| neon lights |
operatic
bump for some HIDs |
unknownstyle
Reg'd: Oct 17, 2007 Oil Changer |
operatic i am disappointed =/ my HID still havent arrive lol |
operatic
Sorry partner. You ordered a Custom Color and those have a 9-13 business day turn around time as they are acquired from our supplier on a per order basis unlike the kevlin colors which we keep in stock. |
operatic
up for some HIDs |
EddiieWard
Reg'd: Dec 29, 2007 Window Washer |
hey is there any way i can get red hid's? if so let me know how much and what i have to do to get them. |
operatic
Yup, we can do red HIDs for you. There is an added $20 charge to em and a 9-13 business day turn around time so you know. I also sent you a PM |
operatic
up for some HIDs |
Reg'd: Dec 08, 2005 |
bump |
operatic
Thanks for the bump partner |
Malinqetoast
Reg'd: Dec 10, 2007 Oil Changer |
Whats the diff between the single and BI ? |
unknownstyle
wooo got my HID but because of the weather cant install them =/ THANKS operatic |
fponce
Reg'd: Nov 02, 2007 Chief Mechanic |
the single is just low beam, like some cars have the low beamand the high beam is like right next to it like the tc has lowbeam on outside and the inside light is the highbeam.....and the bi is the ones that are high beam and low beam...... |
RouletteTc
Reg'd: Jul 06, 2007 Scion Guru |
Damn, after all this bad mouthing of the sylvannia's I've decided I will go HID when it warms up. I guess that's good news for you operatic. ![]() -Thanks for the sig Aciidsneaker |
Reg'd: Aug 16, 2007
Ok, i'm looking for bright HIDS or the violet ones. How are the plug & play kits different then regular HIDS? |
RouletteTc
Plug and play is just a term to emphasize the ease of installation here is his site, which also has custom colors. http://shop.3bspecialties...goryId=6&productId=33 Otherwise I'm not sure what you are asking. ![]() -Thanks for the sig Aciidsneaker |
Malinqetoast
Thanks fponce ! |
BlueFin
Reg'd: Nov 26, 2007 Tech Advisor |
Do I have this hooked up right?? I didn't see a harness for the stock connection (the black and white wires in the right of the picture). Was there suppose to be a harness coming off those wires, or not? |
Seems right....i'm walking another user though the install but I'm figuring it out as we go. Never did H11 bulbs but I've done H7 so they should be somewhat similar.![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
unknownstyle
same problem here man.. no stock relay harness lol |
Tmas
Reg'd: Aug 26, 2007 Detailer |
Those two wires on the far right need to go to the stock connection... either directly or through the adapter attached to the bulb. My relay harness had a harness thing for those two wires tho... |
BlueFin
Yea.. i was thinking the same, but I dont have an adapter like this in the picture. I dont wanna cut any wires... [img]http://home.comcast.net/~...uctions/images/page4b.jpg[/img] |
Reg'd: Aug 16, 2007
I'm sorry, HIDS are not my specialty. I have HIDS but uninstalled, I got them from a lexus and have them sitting in my garage for a year now and its basically two metal boxes which im guessing is the HID ballasts? and some wiring. Anyway, I dont think i'm going to be using them. What confused me is I thought the plug and play was a different kind of HID kit or something. Because they look somewhat different. I went to the site, and I have a question. I thought it was $140 for the HID kit, so why is every option color an extra $20? |
iambryan
Reg'd: Jan 17, 2008 Window Washer |
woo, i woke up this morning to the UPS guy ringing the doorbell to deliver my HID kit. i'm going to install them in a few days. but seeing that i also have an '08 tC, i have the same problem as BlueFin. any help? |
unknownstyle
ask operatic for a new set like me lol |
fponce
[/quote]those 2 cables connect to where the original bulb pluged into on the driver side. Just put one in each little slot and then use electrical tape to cover/hold them to the connector. the plug will be different from the picture of the instruction. |
