| FS: H3 fog light HID BULBS 6000K~~~ |
| FOG-Lights-HID-Converts |
| fog lights on rs4 ? |
| Custom Plug n play zex nitrous kit FS |
way2sxxy4u
dude, i sent the guy a pm earlier in the week n haven't heard from him. any pm's from operatics lately from anyone? i want my 8000k! |
^You ordered yours already? He may not be responding because he may be busy with business and other things. :o man it seems that the forums are going in a modding trend.. before this, it was all about short-shifters and I ended up getting myself one.. this week it's all about HIDs which I'll be getting once I get the cash.. I wonder what the hottest mod'll be next week.. s2k antennas? ![]() ![]() ![]() The Thread Killah |
operatic
I never recieved a PM from you, I just double checked. I pm'd you though |
TongMan
Hey I'm interested in these HIDs for my Anzos. I want a blueish color light output and my bulb sizes are H1 for low beam and H7 for high beam. TRD Supercharged Release Series 2.0 tC ![]() |
6000K will be a LIGHT blue and if you want blue get the 8000K. 10K will be blue in the headlight housing but a purplish on the road. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
operatic
sent you a pm partner |
TongMan
Okay I'm still debating whether I want HIDs for my stock headlights or my Anzo Projector Headlights. I can't swap the HIDs between them right because of the size of the bulbs? What should I do? TRD Supercharged Release Series 2.0 tC ![]() |
Decide on whether you want the new lights housings or not and then go from there....that's all you CAN do unless you want a set for the stock housing AND the Anzos. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
You can but different bulbs and switch them from stock to after. Connect 9006 HID to ballast or H1 to ballast. Correct my if I’m wrong… . 2008 G37 OB Sport 6MT... 2007 335I 4DR... |
Ballasts should be the same for you to just swap the bulbs out. That might be a solution....Operatic should be able to answer that. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
operatic
The ballast are the same. It is the bulbs / wiring harness that are different. No matter what, you are going to want the 9006 wiring harness if you drive a Scion tC. But from there, if you want to use the Anzo headlamps, you will need the H1 bulbs instead of the 9006. The main part is figureing out what headlamp you want to use. |
what exactly is bi-xenon? is it just both your lows and highs? ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
operatic
bi-xenon is for cars that have both there high and low beam on a single bulb and wish to retain there high beam. A good example are Scion xA's and xB's. |
Usually, if your car uses a 9003/9004/9007, your car requires a Bi-xenon kit. I think one of the H bulbs does too...I think it's H7 but not sure. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Teahupoo24
witch HID are for the TC? |
9006 Low beam 9005 High beam ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Teahupoo24
so i need to buy like two sets? |
Usually, people just get the low beams b/c with HIDs, you almost never have to use your highbeams. I only have my low beams (9006) and I'm happy. IF I do use my highbeams, I have silverstars in them and they are fine. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Teahupoo24
How Hard is the install? |
Easy....the hardest part is finding a spot to mount the ballasts. The rest just plugs in. I have my ballasts mounted behind my front bumpber steel reinforcment section. You can stick them behind the headlight housings with 3M tape also. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
For those questioning what 10000K would look like:![]() It's about right where the yellow arrow is pointing. Ultraviolet will range from there and left. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
operatic
Web, I wonder what I would do without you sometimes =P |
way2sxxy4u
yeah i just got this kit n hope to put it on later tonight. for those of u who bought one, did it come with a lil information booklet that has the worse grammar u've ever seen? i had trouble finding a single sentence that actually made sense. where does the kit come from? |
way2sxxy4u
just came back from installing em n taking a ride. i love the look. the light scatters a little bit. all i can say is that i'm glad that i'm lowered. hopefully i'll get to post some pics by the end of the weekend. straightforward install, but the instruction booklet is a bit incoherent (u don't really need them anyway i just found it to be weird/hilarious). i should post a scan of one of the pages. here's an example (i'm not exaggerating!) "For the sake of you and the life of the others safety, please the reasonable usage light!" <----can i get a WTF? LOL. but they are bright ass lights so thats all that matters. just wanted to share something funny. =p |
Just helping out b/c it's a good product ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
