Home > Marketplace > Sponsored Sales > HID Plug and Play Kits $140 SHIPPED Head Lights, Fog Lights
Pages: << 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 >>
Reg'd: Apr 17, 2006
THE SHADOW
tomlin02 wrote:
As i was reading the HID vs. Luminic ...
i think its time for me to change my bulbs to teh real HID...
before i melt my harness
i sent you a PM operatic.
YES!!!
[#] Jul 17, 2007 08:31am
tomlin02
Reg'd: Dec 24, 2006
Detailer
im still waiting for Operatic to reply DDDD
i can't wait myself ....
WEB ..that 10000k you friend have, its very blueish right?
i was gonna get that one cuz i love it !!!
but im afraid of getting pull over by popo
[#] Jul 17, 2007 11:27am
Reg'd: Apr 17, 2006
THE SHADOW
Yeah, you can definately tell it's blue. Next to mine, it makes mine look even whiter
[#] Jul 17, 2007 11:29am
Reg'd: May 03, 2005
El Chupacabra
Man I hope my HIDs get here on friday I can't stand the waiting!
Y s0 S3ri0uS?
[#] Jul 17, 2007 11:31am
tomlin02
Reg'd: Dec 24, 2006
Detailer
how long have you been waitting man ?
are you the one getting the 12000k ?
[#] Jul 17, 2007 12:01pm
slickshot
Reg'd: Apr 17, 2007
i was lookin to get these operatic but could u tell me step by step how id install...is it real easy to mess up??..do i have to aim the hids or anything??...im very convinced to get this because web gives you alot of credit
carpe diem
[#] Jul 17, 2007 01:06pm
Reg'd: Jun 13, 2006
It the easiest mod you will ever do it’s a true plug and play and no aiming of the HIDs required. The kit dose come with instructions as well but you will more then likely get it by just looking at it.
2008 G37 OB Sport 6MT...
2007 335I 4DR...
[#] Jul 17, 2007 01:13pm
Reg'd: Apr 17, 2006
THE SHADOW
Here's a quick step by step:
-get box and open............smile
-now, disconnect both wiring harness connections from stock low beams
-remove stock bulbs and replace with HIDs (make sure long bar is on the bottom........you'll know what I mean when you see it)
-now connect ballasts to light bulbs and mount in a location where they will get substantial amounts of air flow to stay cool and away from any high heat sections (radiator, header)
-now get the wiring harness: parts labeled in picture:
-find the ground wire and bolt it to a section of the body/frame that has a free bolt and is in contact with metal: (circled in red is a good, easy spot)
-now connect the harness to the ballasts (try to run the wiring between the radiator and the front grill so the heat from the header doesn't effect it (it's a tight squeeze but near the front corners of the headlights, there's a small gap to feed it through)
-now connect the driver's side stock harness to the relay harness "stock harness connection"
-Last, connect the red power lead to the POSITIVE side of the battery terminal
*NOTE: Nothing will be connected to the original passenger side stock harness connection on the car so you can push that aside or just electrical tape it and wrap it up.
Now go turn the lights on and enjoy
Some aiming of the headlight might be needed so locate this bolt on the back side of the headlight housing between the low and high beam portion:
Aim the car at a wall on a flat surface and make sure it's about 20-25 feet away. Mark the driver's side wall mark for reference and adjust that screw so that you aim the beam about 1 inch lower. That should be fine for not blinding people but still giving you a lot of extra vision at night.
[#] Jul 17, 2007 01:18pm
Reg'd: Jun 13, 2006
Do any of you guys have problems with the resistors I keep on having to change them out at least once a month.
2007 335I 4DR...
[#] Jul 17, 2007 01:22pm
fusionx
Reg'd: Jul 15, 2007
Window Washer
Hey Guys,
So I want to buy this kit but I don't know which bulbs the lights that I bought take. The lights I bought are:
http://cgi.ebay.com/ebaym...QQitemZ290138084915QQrdZ1
Does anybody know?
[#] Jul 17, 2007 01:26pm
Reg'd: Jun 13, 2006
Those are H1 bulbs for low and High beams.
2007 335I 4DR...
[#] Jul 17, 2007 01:28pm
Reg'd: Apr 17, 2006
THE SHADOW
What resistors are you talking about? I haven't had to replace anything in my kit or fuse box ever.
[#] Jul 17, 2007 01:29pm
Reg'd: Jun 13, 2006
The one that’s goes in to the orange connector in this pik.
2007 335I 4DR...
[#] Jul 17, 2007 01:33pm
Reg'd: Apr 17, 2006
THE SHADOW
Oh, the relay?....No, I haven't had any issues.............do you notice any one of the 4 prongs on the underside getting a burnt coating on it or burn mark?
[#] Jul 17, 2007 01:34pm
tomlin02
Reg'd: Dec 24, 2006
Detailer
WEB...can you explain to me about the ground wire? i always thought those wires would go to the negative side of battery terminal. does it mean the metal i put the ground wire on would have eletric when i turn on my HID? i still dont get the ground wire thing lol ...sorry im stupid
[#] Jul 17, 2007 01:43pm
Reg'd: Apr 17, 2006
THE SHADOW
No, ground wires help "ground" the units out so that there is a consistant current flow and no spikes or drops occur. If there's a spike, rather than it traveling through the circuit, it will dump off at the ground point and be funneled to the ground via the tires. No, it doesn't mean the chassis will be electrified either.
Some people do connect the ground to the negative side of the battery b/c that side is grounded as well. I just choose to have a seperate ground for all my different components so that there isn't an overload on one ground wire from multiple components.
[#] Jul 17, 2007 01:45pm
Reg'd: Apr 17, 2006
THE SHADOW
Wikipedia wrote:
Grounding is primarily used for safety to prevent electric shock or fires caused by a voltage potential between the earth and a conductor such as an appliance cabinet or chassis. Grounding is often used to conduct lightning strikes harmlessly to earth rather than starting fires and damaging equipment. It is also used to control electrical noise in computer, audio and video, and communications circuits
[#] Jul 17, 2007 01:47pm
Anonymous
Oh thx WEBmaster. i think now i get the point. so there is only one wire (red) goes to the positive side of the battery terminal right? the rest of the wires either bolt on the metal or ..connects to the ballast. please tell me im right now lol
Reg'd: Apr 17, 2006
THE SHADOW
Yup
1 hot wire (with eye connector......red)
1 ground wire (with eye connector...black)
2 ballast wires (with connectors....black)
1 socket wire (with male fitting....black)
[#] Jul 17, 2007 01:48pm
Reg'd: Jun 13, 2006
My bad its that relay… Its not getting burnt it just keeps creating lot of condensation and it rots out the inside.
2007 335I 4DR...
[#] Jul 17, 2007 01:54pm
tomlin02
Reg'd: Dec 24, 2006
Detailer
where is our lovely Mr.operatic
i can't wait to buy themmmmm !!!!
i just took off my luminics ...before they burn out my harness.
but it seems like my harness are doing just fine
i hope it doesnt burn out when i switch to HIDs
Reg'd: Apr 17, 2006
THE SHADOW
Try to wrap it with a lot of electrical tape or if you have some, try to heat shrink the entire capsule. Not sure if they make heat shrink that big, maybe industrial heat shrink, but that will keep it dry.
[#] Jul 17, 2007 01:55pm
Reg'd: Jun 13, 2006
You can buy them of the web site if you don’t feel like waiting for him to PM you.
2007 335I 4DR...
[#] Jul 17, 2007 01:56pm
Reg'd: Apr 17, 2006
THE SHADOW
They won't.........the relay harness keeps the current stable through the ballasts and when at operating temperature, they only use 35w vs. 85w like some "HID simulating" bulbs.
Did you order from his site located on the first post of this thread?
[#] Jul 17, 2007 01:57pm
tomlin02
Reg'd: Dec 24, 2006
Detailer
do i get the same price as it states here?
cuz the price on website says 160 ?!
i was reading the first page notes, i guess ill have to wait for him to PM me with the coupon code ?! lol im cheap i know ..having problem with money. 20 is something.
[#] Jul 17, 2007 01:59pm
TOP: Home > Marketplace > Sponsored Sales > HID Plug and Play Kits $140 SHIPPED Head Lights, Fog Lights
