| Fog Lights Problem!! Help Please! |
| Turbo install? Is it plug and play? |
| multicolor under body and interior light kits? |
| parking lights |
| neon lights |
powerhouse21
Reg'd: Jun 10, 2007 Tech Advisor |
hey can somebody post a picture of where you mounted your passenger side ballast? |
I've got mine against the back side of my front bumper....let me find a pic...it's driver's side but still same spot on the passenger's side. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Here's one of my first posts. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
powerhouse21
i had mine right behind the radiator next to the engine and it was getting way to hot so now its tucked to the side above the wheel next to the windshield washer tube with zip ties and industrial strength velcro. |
Mine are attached to the side of the front bummer you have to take off the bumper to put them there. 2008 G37 OB Sport 6MT... 2007 335I 4DR... |
operatic
ba ba bump it up |
bump ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Snider011
Reg'd: Oct 24, 2006 Oil Changer |
just ordered some 4300k... I like pure white! I'm krunk to put them in. |
awesome....................enjoy them ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Reg'd: Dec 08, 2005 |
hell yeah, photos fo sho! (thumbs up) |
Snider011
Just installed them tonight and dang are they sweet. Thanks for the hook up operatic. I might take some pictures. Also I ran the wire across between the header and the radiator, its zip tied to another wire that runs along there... that should be fine right? |
Sorry for jumping in Operatic... Yeah, that should be fine as long as it's away from the header. DO NOT let it touch the header. I ran mine in front of the radiator through little slots between the radiator framing and the headlights. But, as long as you keep it well held away from the heat source (header), you should be good to go ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
operatic
Jump in all you want =P But yes, you should be fine where you ran the wires. |
BUMP...........Best quality HID kit on the market........![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
sofresh23
Reg'd: Jun 04, 2006 Godlike Advisor |
I love my HID's ![]() ![]() |
Yo operatic! You wouldn't happen to sell aftermarket harnesses too would ya? I might need one for my driver's side headlight since the harness burned out ![]() ![]() ![]() ![]() Y s0 S3ri0uS? |
I think on the first page he said it comes with a wiring harness. ![]() "I have an idea! An idea so smart, my head would explode if I even began to know what I was talking about." - Peter Griffin -- Want to post a "For Sale" thread? Check out the rules first. |
Ah you're right Mayo ![]() ![]() ![]() ![]() Y s0 S3ri0uS? |
tomlin02
Reg'd: Dec 24, 2006 Detailer |
so this kit comes with an external FUSE and a RELAY right? cuz i've read about the plub-and-play Wiring Harness, is it true that it has possiblities to fry the stock headlight switch? .....and can anyone tell me if i install the HID kits, what happens to the OEM wiring harness? |
the kit comes with a relay, so you will not put any stress on the headlight switch. The OEM headlight harness does not need to be replaced. It's a plug and play kit that's safe to use |
tomlin02
thank you Mr. Orin. but isn't a FUSE important too? |
a fuse is playing it extra safe, but it's not needed. |
operatic
If you factory harness burned out, hit up AutoZone and ask for a 9006 plug, they sell for about $2-3 and come with pig tails. As for having to use your stock harness, you would have to - to plug in one connection from our harness (that plugs into your factory connection), but you could plug everything in on your passenger side.
There is a possiblitiy to fry your factory connection only if you don't use our harness. As the initial start up of an HID bulb takes 85watts unlike a halogen bulb which only takes 35watts. The only thing your factory connection / wiring does is act as a gate to turn on the HIDs. |
tomlin02
BUMP for great product! i wonder if one day Operatic would be the GOD says "LIFETIME WARRANTY NO HASSLE" lol HAPPY JULY 4th whooooo |
I'm FINALLY ordering these this weekend. 12000k here I come!!! ![]() ![]() ![]() ![]() Y s0 S3ri0uS? |
