Home > Visual / Audio Mods > Mobile Electronics > Eclipse avn2454...
Eclipse avn2454...
Pages: 1 2 >>
swolenoggin
i have been trying to figure out for a long time how to do this to my set up to look like this on this web site. http://photobucket.com/albums/v462/Danno1376/. check it out and please help me anyway you can. reply to this or for faster response email me at de86bl@aol.com thanx everyone.
[#] Dec 11, 2004 04:13am
Tech
that looks like that would take a expert to do, they did a very awsome job on cutting and extending the radio door, thats what your talking about right?
[#] Dec 11, 2004 10:23am
swolenoggin
yea do you think i would have to extent the door? i think the door wont interfer that much. i hope not. i need to find a place that sells the unit as well.
[#] Dec 11, 2004 11:12am
falcon9094
I believe there is a write up on here or scion life so try a search
[#] Dec 11, 2004 12:18pm
swolenoggin
yea i have looked at it and havent found much on it. will a seven inch monitor fit in that space? cause what i think i am gonna do it is just have the monitor in that space and have the reciever probably in the glove box. any suggestions let me know.
[#] Dec 11, 2004 03:14pm
Tech
im an idiot, just went out to my car and took a really hard look at my radio..... the door isn-t extended at all in the pic, i think that stereo will slide right in without any problems, except to mount it without it hitting the door(when shut) but those forums showing install show how to position the stereo to avoid that problemabout my last post... im such an idiot EDIT: and the measurement 7- is diagonally its will fit nicly if you ask me
[#] Dec 11, 2004 10:47pm
scionadmin
  • Admin
hmm I don-t have a tC but at glancing at the pictures it looks like it isn-t that hard to do but requires some time and maybe even some modifying to small parts. I suggest you take a good look again and try to test fit it yourself. If your not handy or good at this just bring it to a shop.
[#] Dec 11, 2004 11:15pm
ToCool
Actually that-s my photo album There-s nothing special about the install, noting was modified but the mounting brackets. The stock radio door fits fine, but it doesn-t push in as far as it did with the stock radio. This means that you need to develop the -tap to open- technique cuz there-s not as much door movement. There is a photo on the site that shows how to modify the bracket.
[#] Dec 12, 2004 01:45am
scionadmin
  • Admin
HEy TooCool you should feel proud that someone wants to copy you . Nice area to put it in though. I like it!
[#] Dec 12, 2004 02:43am
ToCool
Thanks Scionadmin! One (of the many) good things about this car is the flexability one has with such a large, covered radio bay. The AVN2454 is a nice unit and overall pretty easy to install thanks to the connectors being the same as the stock Scion harness, Almost a plug-n-play.
[#] Dec 12, 2004 03:13am
swolenoggin
well i wasnt trying to copy someone my idea was a little different cause i cant afford that unit right now. what i was thinkin about doing was putting just the screen in that space and putting the recieveer maybe in the glove box or something like that unless someone knows of a good unit for a cheap price or any other suggestions
[#] Dec 12, 2004 04:51am
tChillin
Anybody know why that unit wants a signal hooked up to the Reverse lights? I understand the signal from the parking brake. Also, does this unit already come with the NAV package or does it require additional parts?Thanks.
[#] Dec 21, 2004 08:07pm
FastFrank
i think it wants it hooked up to the reverse lights, so if u have a camera when you back up it automatically goes to that video feed. And i believe that model comes with DVD nav disks. but not positive.
[#] Dec 21, 2004 10:29pm
JER5500
weird as soon as i changed my stock radio to my RF 9400 the door miraculously worked even better than before. i rememer than when i first got the car i had to push the top right corner for it to open properly. now i don-t have to do anything just push in and it opens. all you have to modify is the mounting brackets that is by drilling a new hole about 1/4- 1/2 of an inch from the previous hole to make the door work properly.maybe thats why its now working for you as it should also they have a kit that its now avaliable for ppl that don-t want a double din stereo.
[#] Dec 22, 2004 03:46am
Lexington
Kentucky, US
  • The Gearhead
Just fyi that the reverse cam is an accessory. It doesn-t come with the unit. But still a very cool feature!!
[#] Dec 22, 2004 07:04pm
unclemow
Stockton
The unit has reverse signal wiring because it-s for the Nav unit, it-s letting the unit know you are in reverse and not going forward, The nav guy would not be accurate too if you don-t install the cable. The AVN2454 does come with a 8.5GB DVD that contains entire US maps and Canada. One thing you might want to know is AVN2454 is a 4 channel system so if you think about doing 5.1 sound in the car, you will need the AVX series which is a true 5.1 surround system. As for backup camera Eclipseonly has a -Back eye- camera where it is manually switch on by the driver when you want to, it is not a -back up camera- where the video auto feeds when the car is in reverse !!! I know since I have both unit the AVN2454 and BEC103. You can install other brand like Pioneer where it-s a true backup camera ( you might need additional hardware to install that though, I am not sure ) Hope this make sense for you.
[#] Dec 24, 2004 02:37am
tChillin
Good info. ThanksI dont see the right size box under the Christmas tree though. Guess I,m on my own there.
[#] Dec 24, 2004 12:27pm
unseen
Hampton Bays
are the eclipse dimensions exactly the same as the kenwood ddx? im going to install mine next week; just want to get a heads up on need for spacers, etc.
[#] Feb 16, 2005 08:31pm
unclemow
Stockton
sorry I don-t know, I did have to get my buddy to custom fabricate2 side panels for the eclipse so that the unit fits in snugly. Since the Pioneer deck is so much wider than the eclipse. Check on the product-s website and get the dimensions.
[#] Feb 16, 2005 08:49pm
Lexington
Kentucky, US
  • The Gearhead
Check out the link. First post in the tread, good reference.
[#] Feb 17, 2005 08:12pm
SciontC18
how much was the avn2454 ?And how much do you think it would be for a professional install.. thanx
[#] Feb 17, 2005 09:35pm
unclemow
Stockton
The retail MSRP for AVN2454 is $2999, most fine electronic eclipse retailer may sale it for 2299. I got mine at Good Guys for $2000 installedso basically $1800 for the unit, $200 installation because there are a number of sensors that need to be installed on the car in order to get the full use out of the nav system.
[#] Feb 20, 2005 03:35am
speedaddictsdj
-daythinkr- wrote:
is this brand any good? would this component give me problem later on.
If you are referring to the Eclipse AVN2454, YES it is a VERY GOOD brand and highly recommended. Eclipse is a higher end market brand, and their product speaks for it. They have also introduced 2 new double-din displays at the 2005 CES Show to be released soon. I apologize I do not have the new model numbers off hand.
[#] Feb 23, 2005 07:05pm
TC4ever
Hi everone....new to this club and I-m getting my TC on 3/2/05 and there is alot of things I plan to add to the car. The Eclipse AVN2454 is the perfect choice I think. But how do I get one? And where do I go to get it? help me please......TC4ever.
[#] Feb 26, 2005 03:54pm
unclemow
Stockton
For retail, any major electronic store that are authorize retailersand you can register your eclipse unit for 1 year theft replacement.and warranty. For online , ebay check to see if they come with the map DVD, otherwise it-s useless but bad part is you can-t register the unit because it-s not sold from an authorize retailer and eclipse will not honor the theft protection if the unit is stolen with the 1st year. Nor will they honor the warranty with the same reason.
[#] Feb 27, 2005 05:48pm
Pages: 1 2 >>
TOP: Home > Visual / Audio Mods > Mobile Electronics > Eclipse avn2454...
