Home > Performance Mods > Exhaust > header and exhaust.
header and exhaust.
trick
Killeen
i just bought a dcsports racing header and a zpi full exhaust last night. i can't wait to put it on my car. does anyone have both of these? how deep of a sound does it have? i hope it is not to loud, especially when i put the turbo in.
[#] Dec 12, 2006 08:07am
Well, you know that with the turbo the header you have will be removed and have a different manifold installed...that's a given. Your setup right now, unless ZPI added another resonator into the mid pipe, will have a good bit of rasp. The DC Sports header looks great and produces a fair amount of power, but seems to be the one that produces the most rasp. Get a resonator added into the mid pipe or check out my "Spintech Installed" link. Check out the spiral flow race muffler/resonator I had to install b/c of overall rasp. Now, my car is great .
[#] Dec 12, 2006 08:29am
trick
Killeen
damn. well i guess it is a good thing that i will only be driving with this setup for about two weeks in march, then another two weeks in november. then the turbo will be going on. so i won't have to listen to it long.
[#] Dec 12, 2006 03:27pm
I wouldn't waste the money on the header then. If you're only going to have it for a total of 1 month, you're wasting that money. Just add it towards your turbo kit since it comes with it's own manifold.
[#] Dec 12, 2006 03:29pm
trick
Killeen
what are some suggestions for other things i could be getting, while waiting for the turbo? stuff that will actually still be on after the turbo.
[#] Dec 13, 2006 06:43am
Intake and header would be the only 2 things that would have to be replaced.
So, s-pipe, mide pipe, exhaust, pulley, HIDs, brake kit (will need for the turbo unless you're not going to use the boost )....strut bars F/R, sway bars F/R, ....short shifter, clutch, flywheel.......... hope this all helps
[#] Dec 13, 2006 08:23am
TOP: Home > Performance Mods > Exhaust > header and exhaust.
