| DIY: Tail Light Tints |
| DIY: Removing the Waterfall |
| Duplicolor Caliper Paint DIY (Tons of Pics!!) |
| **New Shoes!! and Grills** Check It out! |
| Seatbelt Beep Disable DIY |
Here's the steps: 1)loosen and return cable to stock (about 13 clicks to full lock) 2)make sure front wheel doesn't move (block in front or behind depending on how you are facing a hill) 3)remove back tire (make sure ebrake is NOT engaged) 4)turn rotor until little black rubber cicle is in 6 o'clock position ![]() 5)use a flat head screw driver and remove rubber circle 6)look into the hole and find a gear looking screw (the picture shows the rotor removed but there's no need .........the gear/bolt is at the bottom) ![]() 7)use flat tip screw driver and place at bottom of gear and turn gear upwards (this pushes the shoes against the rotor drum) 9)when you feel the screw stop, place the screw driver at the top of the little gear and push it back down about 2 clicks..(you will feel the rotor loosen and spin free again) 10)replace little rubber circle and wheel 11)repeat steps 3-10 on other side Final look: (Fully locked is less than 1/2 the distance it used to be) ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
klepto
Reg'd: Aug 31, 2005 Master Mechanic |
thanks bro....i was just talking about that w/my other buddy when we did my sways and the week before when we did my rotors... |
Yeah, it's a great feel and definately a lot better when parking on hills. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
rrimportracer
Reg'd: Feb 28, 2006 Godlike Advisor |
i think you have to do it if you lower your car, ever since i lowered my car i havent been able to get my e brake to fully lock my rear tires up, im about to do it on my car today or tomorrow ![]() myspace.com/asphalt_photos check us out!!! |
Weird. It must have a suspended joint holding the metal line mounted to the frame which creates more slack when lowered. hmmm ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
soros151
Reg'd: Dec 01, 2006 Tire Changer |
Thanks, this helped me a lot! Either u do it, or u don't, No regrets. U gotta Pay to Play. 159whp/161wtq. |
lol that might explain why my car rolls back a little when i put the e-brake up on a hill ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
soros151
Good Add! Either u do it, or u don't, No regrets. U gotta Pay to Play. 159whp/161wtq. |
thanks, i thought it would help out a bit. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
haha, we should make video tutorials on how to install radios, subs, springs, and other stuff. |
It would definately be a good idea to go along with written/pictorial documents. I have my tripod I can mount the camera on and do my tutorials ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
heh, i still have 1year and a half of free oil changes (havnt used one yet). first one in 5 months |
I still have 3 free ones ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
i dont trust the dealer that much, but i take pictures of my cars exterior and interior and i will rage on there ass if the pics dont match up |
Damn, i'm lacking tools to adjust the bolts >=[ i'll do it at the shop next week. I inverted that silver ring between the shift knob and boot.. looks alot nicer and makes the boot look alot baggier ![]() ![]() ![]() ![]() Y s0 S3ri0uS? |
Yeah, my boot was all compressed so I did it for that reason too ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Aciidsneaker
Reg'd: Feb 24, 2007
Nice DIY Web. ![]() |
Thanks. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Dr_Isotope
Reg'd: Sep 02, 2005 Chief Mechanic |
It's not even remotely the same. Adjusting the brake tension in the drum (As you should do) does not affect the tension on the cable one bit. It moves the linings closer to the drum so when you pull up the parking brake handle, they have less distance to travel. When you adjust as the handle, you're just making the handle harder to pull. My handle is 4 clicks to full lock, even when parked on an incline. I've never touched the adjustment at the handle end, but IIRC, there's about 1/4" of thread showing. If you crank the cable as tight as you want to keep the low handle height, one day, it will fail. Not today, not tomorrow, probably not this year, but every time you pull up on the handle when parked on a grade, you're stretching the cable. One day, the weight will be just right, and it will give out. Last I heard, replacement parking brake cable-Y runs about $300. Add that on top of the cost of whatever your car rolls into. ![]() Custom parts for your Scion tC: Doctor Isotope dot Com |
I don't pull for dear life on my ebrake handle to engage it though. I can see that being a problem if you yank on it hard (not that it does anything more than a normal pull), but for how I pull on it and where I park, I almost never NEED to use it, i just engage it out of habit. I was in the rear section of the car at first, but could not find the adjustment cable or some sort of expansion screw that could be adjusted. Do you have any pictures/DIYs as to how to do it from the rear brakes? If so, I'll loosen the handle and tighten the shoes....I just haven't had any negative effect from this at all. Even when I changed my rotors, the inside (drum section) didn't have any pad scoring/wearing as some others had warned me about. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Dr_Isotope
Just remove the rubber plug and adjust the tensioner with a small screwdriver. Rubber plug should be at the 6 o'clock position. No need to take anything off of the car other than the tires. From the outside: ![]() From the inside: ![]() Custom parts for your Scion tC: Doctor Isotope dot Com |
Alright, thanks. Didn't know if it was setup just like a drum brake setup....Just like my truck. Thanks, will do this this weekend when I am painting my calipers and rotor hubs. **but fair warning to people that do it this way too..........you CAN over tighten the shoes on the inside of the rotor hub and cause heat glazing of the shoes and possibly crack the shoes or rotor from excess heat build up. Almost did that on my truck. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Dr_Isotope
The rule of thumb is to tighten it until it won't move, then back off two clicks. Mine was so sloppy loose from the factory, the driver's side adjuster took 21 clicks, and 19 for the passenger side. Looooose. ![]() Custom parts for your Scion tC: Doctor Isotope dot Com |
Geez.....that's rediculous. Just like regular drum brakes though, since you have to back off, it has a small spring loaded arm that can be pushed off and the screw spun in reverse correct? ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Dr_Isotope
Yep, it's a typical drum brake under there. It doesn't self adjust, because they don't want constant lining to drum contact.![]() Custom parts for your Scion tC: Doctor Isotope dot Com |
