Home > User Content > DIY / Install Guides > DIY: Oil Change
DIY: Oil Change
Pages: << 1 2 3 4 5 >>
~3-4$
[#] Mar 21, 2007 02:01pm
de16
wow stupid dealership tq'd the fucking oil filter on!!! fucking took me 2 hours cause i had trouble taking off the oil filter even with a oil filter wrench. man fucked up shit
[#] Apr 09, 2007 06:02pm
sfdee12sf
hey guys, quick easy question....cant find my manual right now for sone STRANGE reason....can someone get there manual and check oil quantity with filter for me please.....is it exactly 4 including filter change?? thanks
[#] May 08, 2007 08:27pm
sfdee12sf
Bumb.......can anyone answer
[#] May 08, 2007 09:48pm
you only need to do 4 quarts. I believe it says 4.2 but 4 quarts is fine if you use the stock size filter.
[#] May 08, 2007 09:49pm
dsm3383
Rochester
I like our oil change......soooooo damn easy and quick. Yea, I only use four quarts and fills up right to the money with a PUR ONE Purolator synthetic oil filter.
-Ben Franklin
[#] May 08, 2007 09:51pm
Stock toyo filter for me and Amsoil
[#] May 08, 2007 09:55pm
BlackRose617
Boston
Massachusetts, US
havent yet changed the oil on my tC myself ('07 and still milking the 3 free ones), but on my previous mustang and explorers you had to replace a washer that was on the drain plug bolt. i take it the tC doesnt have one that needs to be replaced?
GUN CONTROL IS BEING ABLE TO HIT YOUR TARGET
[#] May 08, 2007 11:29pm
dsm3383
Rochester
Yes you need a new gasket every time you do your oil. Doesnt come with a permanent gasket sytle plug. Which is a bummer. I am going to buy a permanent style plug though cause I always forget to buy the stupid gaskets when I'm at the store!!!
-Ben Franklin
[#] May 09, 2007 12:04am
BlackRose617
Boston
Massachusetts, US
damn, well we should throw that into the write up
[#] May 09, 2007 06:45am
Is the 07 plug different? I haven't replaced my plug gasket on my 06 and I've done PLENTY of oil changes. (38700 miles right now)
[#] May 09, 2007 09:12am
dsm3383
Rochester
Ummm....Web if there is a seperate gasket for your oil drain plug you are advised to replace it every time you change your oil. If not you have a possiblity of leaking oil at the plug.
Now if your plug has no seperate gasket and a rubber gromet/washer on it then its a permanent gasket. I don't think the older models would have this and the new model does not.
Just a heads up Web.
-Ben Franklin
[#] May 09, 2007 10:49am
Never had a leak but now that I just thought about it, my oil plug doesn't have a gasket.....it's always been metal to metal. Also, I've never heard of replacing the oil drain plug gasket at EVERY change either. Only if you notice a leak or when you take the plug off, the gasket is cracked.
I've had the same one on my truck for 165K+ and it's never leaked a drop and it's a seperate rubber/nylon gasket.
Also, it depends highly on how much your torque that plug on. If you torque it on like some quick lube places, then yeah, i'd change it every time. It only needs to be torque to maybe 15-20 lbs at the very most. I just wait until the bolt stops turning and give it a 1/4 turn more. Never leaked on me with my truck or tC so far.
[#] May 09, 2007 10:56am
dsm3383
Rochester
I always replace the gasket. Every job i worked when I was a mechanic I did so with every gasket you took off....with the exception of permanent gaskets.
I think its a good idea especially when those things cost 15 cents for a pack of ten.
-Ben Franklin
[#] May 09, 2007 10:58am
BlackRose617
Boston
Massachusetts, US
yeah ive always replaced them on my previous cars
[#] May 09, 2007 11:03am
hhhmmmmm.....oh well..........guess I'll just see what happens........but i am almost 100% that my tC doesn't even have one.....just metal to metal contact....i'll check in 5K
[#] May 09, 2007 11:06am
dsm3383
Rochester
WHAT! Metal to metal contact with no gasket! Dude, slap a gasket on that pronto.......i thought you originally said it had a metal style gasket but if its just a drain plug and nothing else then you want a gasket......especially not to mess up your threads on the pan from the torque of tightening the bolt.
-Ben Franklin
[#] May 09, 2007 12:46pm
I'll check it out next time. Unless it's got a recessed gasket into the head of the bolt, I don't remember one being there......oh well.......
I'll check next oil change though
[#] May 09, 2007 12:47pm
dsm3383
Rochester
Yea, if you have a recessed gasket embedded in the bolt (aka permanent gasket) then your good. But otherwise I am suprised your not leakin oil with no gasket...very surprised!
-Ben Franklin
[#] May 09, 2007 12:49pm
Then I most likely have the "permenant" gasket. I've never noticed on fall off when I take the bolt out and never put anything between the bolt and the pan......just never paid attention. Never had ANY leak
[#] May 09, 2007 12:54pm
dsm3383
Rochester
Nice quotation for "permanent gasket"
Letting everybody be able to distinct what it is and you explained it better than me in your post.
-Ben Franklin
[#] May 09, 2007 12:56pm
hahaha...........
[#] May 09, 2007 12:57pm
swiftprov
Naperville
Illinois, US
It's better to change your oil when your car is hot right?
[#] Jun 17, 2007 07:26pm
Winter Park
so web does ours have a permanent gasket? and do u have to put oil into the filter or can u just slap it on and when u fill the 4qts let it flow into it
[#] Jun 17, 2007 07:38pm
o7SCIONtc4gg
Pottstown
Pennsylvania, US
how many quarts of oil do we use? 4?
[#] Jun 17, 2007 08:07pm
TOP: Home > User Content > DIY / Install Guides > DIY: Oil Change
