Home > Performance Mods > Suspension & Brakes > S-tech install??? ride hight??? settle???
sfdee12sf
ok so i only had about an hour or so last night to work in switching to s-techs..... and i only did rear left.....not worried aboud about it cause i wopnt be driving it.....but for those of you that installed your own.........when changing do you need to alter the strut at all......and shouldnt the top strut screw thing be longer with the shorter spring on, because mine wasnt... i read on the trd spring diy he cut the bumb stop, do you have to do this, for the lower ride...and what is that......i put it on, and took off the jack...and its lower...but still has a wheel gap....does it take a while to settle.....or did i do somthing wrong....... thanks dayne
[#] Aug 15, 2006 07:48am
guitarguru44
South River
the back doesnt drop down as much as the front. it still has to settle. The bump stop is the tan rubber type piece. Cut it to what the instructions say (I think 1.2 inches)...
I can CUSTOM paint/smoke basically anything on the tc.. headlights, taillights, trim, etc. Drop me a PM if interested in some work. Check out the links to my work.
JOE
http://clubsciontc.com/fo...illights--trim--etc-.html
http://www.scionlife.com/...pic.php?p=2295520#2295520
[#] Aug 15, 2006 12:10pm
sfdee12sf
but i still fit like 3 fingers between tire and car....and the bumb stop, is it?....the rubber washer thing all the way on top, under the nut..or is it the rubber neck that goes around the strut??? ....or the big rubber shoe thing that fits right on top of the spring.....so cut an ince of the bottom of either...will that lower it even more.....but thanx in advance, and thanks already guru
[#] Aug 15, 2006 03:23pm
sfdee12sf
sorry but more questions.......sut the bumb stop to 1.2 inches long...or cut off 1.2 inches, also do i do this on the rear, or just the front....and what does this cutting do????
also guru....do u have im so we can contact back and fort faster??
[#] Aug 15, 2006 05:26pm
TOP: Home > Performance Mods > Suspension & Brakes > S-tech install??? ride hight??? settle???
