Home > Performance Mods > Engine Mods > Automatic engine mods...
HUNT
I am wanting either a Supercharger or Turbo kit. Do they make either yet for the Automatic Tc?
[#] May 29, 2006 07:12pm
HUNT
Nothing out there or no-one knows? I have read that the supercharger out is only for Manual transmissions, but what about the turbo kits?
[#] May 29, 2006 10:39pm
Absolut_tC
there is an adapter for the supercharger, not sure about turbos though
[#] May 30, 2006 12:01am
HUNT
Really, what does the adapter run?
Thanks for the reply.
[#] May 30, 2006 10:13pm
Absolut_tC
not sure, ive only seen posts about it
[#] May 30, 2006 10:21pm
Mick
The supercharger has an auto tranny mod out for it now. As far as turbo kits go, the turbonetics and ZPI (stage0 not sure about stage 1) kits are both available for auto trannys. At least that what their advertising on turbo kits.com
http://www.turbo-kits.com/tC_turbo_kits.html
[#] May 31, 2006 02:38am
Gargoyal
TRD has an auto supercharger kit out now
http://www.trdusa.com/featuredpart.cfm?part=tcsupercharger
If your going to boost an auto, you may want to look real hard at a supercharger. The boost is more consistent through out the RPM range. Because it is harder to control your RPMs with an auto, you will probably get better overall performance from a supercharger. HP is not everything in performance.
If you are serious , make sure to shop around for the kit and the labor. Toyota dealers cut deals on parts and labor. My supercharger cost $2900 and the labor $425. $425 was a misquote , but they had to stick to it.
[#] May 31, 2006 08:02am
klepto
other things you can do to an auto are as follows:
torque converter
LSD (limited slip diff)
these will help as well in performance and will do a great turn out w/ a TRD SC as well.
[#] May 31, 2006 10:16am
Mick
Dezods turbo kit is offcially out for autos now too. I really like their stuff, Im gonna buy my turbo from them here this summer!
[#] Jun 01, 2006 05:29am
tC_skier
i want to get a zpi stage 0 sometime soon but i keep hearing that a lot of people sell their tC's immediately after turboing......can someone explain to me what the reasons are behind that? if its problems they're having with the engine cause of the turbo, then i dont want to be stuck with it......
[#] Jun 13, 2006 01:07am
josh_trdsparks
Yes there is an auto fit kit that is available for the S/C. There are a few turbo set ups that are available for the automatic as well. If you have questions about the S/C let me know.
http://www.trdsparks.com/...at=3&parts_id=634
[#] Jun 13, 2006 09:01am
tC_skier
bump for some answers...
[#] Jun 13, 2006 09:28pm
djslimdj
there is a part for the TRD Supercharger to work on auto trann. its part number PTR01-21051 and goes for about as high as $55 to as low as $42, depends on where you shop.
[#] Jun 14, 2006 01:55am
540
Yeah, buy the $3500 TRD supercharger so you have 200 horsepower and can compete with stock cars
[#] Jun 17, 2006 04:28pm
hsua
if you have the money, go for the turbonetics. For almost the same price you are getting almost 100% more hp. But then you have to find someone to install it for you, unless you are good at those kinda stuff (I know I'm not..)
[#] Jun 28, 2006 12:41am
HUNT
When I had my Matrix it was the same thing. Some kept the car, but many sold them. My thought would be, now you have done everything you can do (not really, but kinda) and they have nowhere higher to go. I mean, yes you can go stage 2 and 3, but once you get the car to a certain point it will be unreliable for a daily driver.
[#] Jun 28, 2006 06:50am
Angry_G00k
Colorado, US
Do not turbo autos because you'll kill the tranny faster than you think. I had been told by many who said that turboing for auto is bad because once when it goes out, you have to replace the entire TRANNY instead of the clutch.
[#] Aug 11, 2006 03:22pm
TOP: Home > Performance Mods > Engine Mods > Automatic engine mods...
