| FS: 18" x 7.5 Konig Hotswaps |
| new rims |
| about rims |
| Will these rims fit? |
| What Rims Are These |
GReddyTC
What is the proper offset for an 18X7.5 rim on the tC, I would like the wheels to sit a little closer the fenders say like 5-10mm. THanks again, these offsets always screw me up! |
raw
hows that greddy exhaust sound on yor tc u like it? |
GReddyTC
It sounds great, I dont have headers or and intake so I dont know what it sounds like with those but with just the exhaust it is very throaty for a n/a 4 cyl. |
dp-_-
Look for the +45 area. You're not going to find many wheels with that offset, but that's what spacers are for |
GReddyTC
not a fan of spacers but thanks for the info. |
HKSpeed
18x7.5? you can go et30 in front, et25 rear. this is without rolling fenders using 225/40/18. i had 18.7x5 et33 front, et28 rear. i was able to put a 5mm spacer front & rear without rubbing. i was dropped 2.5 inches. |
GReddyTC
So the rims I want come in 18X7.5 and offer 48 43 and 35 mm offsets. What do you think? I used the offset calculator and I am not sure how much clearance there is stock between the strut housing and the wheel. Anyone know? |
Why are you getting a wider rim if you are putting a tire that would fit the same width rim as stock?...It's not going to look any wider but you'll spend more money. I had 225/75/14s on my truck and that was on a 7 inch rim. [url=null]http://forums.focaljet.co...s-tires-7-inch-wheel.html[/url]
![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
