Home > Visual / Audio Mods > Mobile Electronics > problems with sound system.
jmoney
Jacksonville
ok so like for some reason my system keeps cutting off when turned up. i thought it was because i didnt have a big enough ground wire (8 gauge) so i went ahead and changed it out with a bigger gauge wire (4 gauge). but now the amp wont even turn on. im thinking its the remote wire that connected into the fuse box under the dash but not sure. ima check it out tomorrow after school. does anyone know why my amp wont turn on now? ads;flkjads;gklja.
[#] Apr 12, 2006 06:18pm
rtiid22
If you didn't disconnect the negative wire from the battery before you messed around with your system, there is a posibility that you blew the positive wire fuse. Have it checked out at a sound store, just because it isn't broken down the middle doesn't mean it isn't blown.
[#] Apr 13, 2006 01:58am
SoFloTC
Boca Raton
ur amp cant power the subs properly.. get a better one more wattage.
[#] Jul 30, 2006 05:31pm
TCFuzion
Sounds like you're wiring is a bit funky. Probably blew a fuse.
Rather than do any more damage..if you don't know what you're doing, take it to an audio shop.
[#] Jul 31, 2006 12:02pm
Lynn_tC
Why is your remote wire going to your fuse panel? That should be going straight to your radio.
Chris Clocher
2005 Scion tC - 5 speed
[#] Aug 04, 2006 10:04am
TCFuzion
haha...I must have skipped over that part. Yeah, that def is your prob. Remote AND RCAs both run from the back of your HU to amp.
[#] Aug 05, 2006 08:22pm
nick06tc
Not always true. A stock headunit probably wont have a remote out. So you can attach the remote wire to any source that turns off with the ignition. It does not have to run to the headunit. Just needs to run to a power source. Mine runs from a power source to an inline switch to the amp and works just fine.
[#] Aug 20, 2006 12:13pm
TOP: Home > Visual / Audio Mods > Mobile Electronics > problems with sound system.
