Home > Visual / Audio Mods > Show Off > Ground Controlled tC
hb
[#] Feb 21, 2006 10:28pm
hb
[img]http://www.myfruityimage.com/uploads/5b373b1b98.jpg[/img]
[#] Feb 21, 2006 10:38pm
hb
[#] Feb 21, 2006 10:40pm
hb
[#] Feb 21, 2006 10:41pm
b_WET
u do knoe you could have just put all the pics on one post, u didnt have to reply like 5 times. lol.
but ne ways the drop looks good, how low?
[#] Feb 21, 2006 10:58pm
hb
yeah im new to posting pics man. dunno how low. all the way down in front, almost all the way up in rear
[#] Feb 21, 2006 11:16pm
atodak
New Hampshire, US
yo hb, it looks like you've got too much rear camber there....or is it just the pic
[#] Feb 22, 2006 07:42am
Auburn
Alabama, US
What kind of springs and shocks are on your ride?
[#] Feb 22, 2006 09:25am
NYTCFresco
The back looks lower then the front, He probaby got Hotchiks set up.
[#] Feb 22, 2006 10:54am
josh_trdsparks
When you say "Ground Controlled" do you mean Ground Control coilovers? Just wondering.
[#] Feb 22, 2006 11:12am
semaJ
it says it in the title...ground controlled...
im assuming he has ground control coilovers. its a big suspension company for hondas and stuff.
and just because the rear is lower does not mean he has hotchkis set up.
[#] Feb 22, 2006 01:52pm
hb
yeah you're right. the front is higher than the rear. i dont know why. they are ground control coilovers on stock shocks. it rides okay. maybe i should switch the front spring w/ the rear.
right now the front is all the way down and the rear all the up
[#] Feb 22, 2006 10:20pm
ih8civx
you casn adjust ground controls which means one is prolly higher then the other. Check the red line. I had GC's on my cougar i used to show. They were great but if you dont upgrade the struts, you will be replacing them once a year if not worse. I fugred 400 for gc's and 500 for some good Koni Struts, it was cheaper to get my Tein superstreets...
[#] Feb 23, 2006 03:42am
TOP: Home > Visual / Audio Mods > Show Off > Ground Controlled tC
