Home > Performance Mods > Suspension & Brakes > Are these any good?
Are these any good?
atodak
New Hampshire, US
CIRCUIT PRO COILOVER KIThttp://cgi.ebay.com/ebaym...1&item=7986727018
[#] Jul 20, 2005 10:02am
TRD_tC
Instead of choosing cheap springs, with little to no names, and asking if their good or not...why don-t you spend the extra 20$ and get the Tein s-techs, or the TRD, or the eibachs...something with a reputable name...generally, the cheaper it is, the quality goes along with it... not always the case... but think about those no name products out there...what sounds better, the JL subwoofer, or the MONSTER made by pepboys? try going on e-bay and consider spending a bit more to get the tein s-techs...
[#] Jul 20, 2005 02:28pm
atodak
New Hampshire, US
I might get stechs or trd but with the stechs I-ll need to change the struts too. I-ve heard some tC owners blowing out theirs....What do you recommend for struts with stechs? Also I plan on driving my tC in the winter so wouldnt stechs be too low?
[#] Jul 20, 2005 02:35pm
TRD_tC
the TRD struts should do just fine... they are the only ones on the market right now worthy of performance, and true to the bolt-on strut...*no cutting here!*I-d wait a few more months before OEM or Equivalent is sold at car stores such as monroe, or kyb...
[#] Jul 21, 2005 12:27am
bigaznn
eventually with any spring you-ll have to change the struts, the reason is b/c the lower spring has less travel and that will eventually wear out the struts, with aftermarket struts they are made shorter and therfore has less travel and will end up lasting longer. Tein also makes a damper kit that has coilovers and struts all in one, which is the best deal overall.
[#] Jul 21, 2005 03:54am
TOP: Home > Performance Mods > Suspension & Brakes > Are these any good?
