Home > Performance Mods > Suspension & Brakes > Teins or TRD??
Teins or TRD??
tru3aznplayaz
Which gives u a lower drop?? Tein S.tecs or TRD
[#] Jul 11, 2005 08:15pm
CaliRow
Santa Barbara
S techs, use forum thank you
[#] Jul 11, 2005 08:16pm
TRD_tC
Now, to ADD onto this forum, because i wanted to start this thread too...WHich one do you prefer? Does the TRD suffice a decent drop, i udnerstand the Tein is a more aggressive drop, but will i run into Camber and toe and other such aligment/tire/suspension problems down the line. ... As the TRD looks like, i wont have too many problems as the DROP is not big enough.Does anyone scrape with the TRD, ANY time, i don-t care if it steep, speed bumps, do you guys scrape? how about you guys with the Teins?My birthday is comming up, my dads buying me springs, s0 im looking towards tein vs. trd....making my final decision soon ya-ll, help me out! haha...
[#] Jul 11, 2005 08:19pm
CaliRow
Santa Barbara
i had the same questions but for me i do alot of drunk driving j/k but im not to crazy on having to ride 5 or 10mph on a 45mph street cuz i know a dip or one of the 5,000,000 pot holes in my city are coming up, if i had s techs i could say i just might accidentaly niglect my driving sometimes. do i have to worry much with the s techs or would you say i should go TRDs?
[#] Jul 11, 2005 08:28pm
smooVtC
since you guys are talking about springs i thought i would add another brand in the mix, no point in starting a new thrend. How are the Tanabe springs? Anybody have those springs with pics or some info?
[#] Jul 11, 2005 09:04pm
rsworksTc
Check out my website I got photos of my setup. I went with the Tein S springs. I also put on the Hotchkist rear upper links, front strut bar, TRD rear swaybar, and H&R front camber kit. I love the look of the Tein S drop as the TRD is just not low enough for me. I do not like in gap between the tire and the fender. The ride is not bad as I kept the stock shocks a little bumpier but not much a lot firmer in corners. Most ride comfort comes from the shock design. That is why air bag rides are so smooth. The clearance is an issue but not totally bad just know what you can and can not do. For instance no more automatic car washes the tracks are to high. Enter at angles on steep entrances. Be careful with potholes if you have stock tires the regular potholes should be fine. Large potholes will kill even with stock suspension. Just becareful. I am getting my 19-s on next month then I will have to navigate streets like an expert. But style comes at a cost. Website
[#] Jul 12, 2005 07:10am
Scionic_tC
^ those rims are nice i was thinking about those for my flint. when you putting them on? lemme know if you rub with the 19-s.but back on topic i have the tein s-techs to and i think there great i would preferr them over the trd nice drop, handle and stance.heres a pic to show you:
[#] Jul 12, 2005 10:27am
rsworksTc
Scionic_tC are you going to the Mid-Ohio Track Scion Show on Aug 27th. If so you can see the car in person with the 19-s installed.
[#] Jul 12, 2005 01:21pm
LavaOrang3
-rsworksTc- wrote:
Check out my website I got photos of my setup. I went with the Tein S springs. I also put on ....H&R front camber kit.
Did you need to get the camber kit because of the springs?
[#] Jul 12, 2005 06:37pm
rsworksTc
Yes, IMO for the most precise handling and to keep camber with in specs the camber kits were need for the Tein S. If you check photos of my car lowered and Scionic_tC. You will see the difference in camber even visual is different. The stock suspension can not remove all the negative camber that is introduce to it without the kits. While more negative camber is good in corners to much can cause issue also the balance must be found. With my suspension I now have that adjustability + or - 3 degrees to fine tune. I have currently set the camber at -.5 degrees factory setting and even with pushing the car have not induced oversteer that some are feeling with tien s or swaybar setup. I believe this oversteer may have something to due with to much negative camber.
[#] Jul 12, 2005 09:06pm
tChillin
I have had absoloutley no scraping with the TRD springs. I will also add that I do have the OEM ground effects. My car sits on 18-sw 225/40rz18 tires . Wheel/tire size will have alot to do with the gap and if your going to scrape or not so, you should post your whole setup for advising on this topic. Just my$.02 though.
[#] Jul 13, 2005 01:32am
guitarguru44
South River
i just bought tein s techs
[#] Jul 13, 2005 11:23am
TOP: Home > Performance Mods > Suspension & Brakes > Teins or TRD??
