rsworksTc
Attached are pics of my progress I have had my car since Feb 05 and bought it without any options. It was actually the only car without options at the dealer and was hid in the back with a bunch of Camrys. I have so far in no order add to my car OBX Shifter, pedals, tC door sills, TWM Stage 1 Short Throw Shifter, Tsudo Slant Axle-back exhaust, K&N Typhoon CAI, TRD Radiator Cap, LED Hyper Purple bulbs inside and out, Super Violet Headlights, 30% all round window tint.On deck and ready for install on July 2nd: Tein S Sport Springs, Hotchkis Upper Front Strut Bar, TRD Rear Swaybar, Hotchkis Rear Camber Kit, and H&R Front Camber Kit.In my basement waiting for tire to be ordered next month. Axis Hiro Gunmetal 19x8.5 with 35mm offset. |
rsworksTc
check link to view |
DTRUONG_112
how much did you spend for the front and rear camber kits and where did you get them at? |
rsworksTc
I purchased the H&R Camber Bolt Kit for 45 shipped from eurosport part# TC117 and the Hotchkis rear camber links for 200 shipped from the store on this site |
rsworksTc
She has been lowered check page four of my website phote up of installed parts and before and after pics. Next up tires and rims and brake kitswebsite |
guitarguru44
thats ugly... nahh im just playin, anyways do you need a camber kit if you lower and have 19s, thats what ive been hearing and im about to lower it, please message me if you could thanks, and im really just playin your car is lookin nice keep it up |
rsworksTc
IMO, I would also get the at least the front camber kit. As the rear does have some small camber adjustment. The Hotchkis adustable rear link is expensive but the adjustablity and quickness to adjust it was well worth it. I am able to fine tune the suspension. And I believe the 19s will exagerate the camber issue without the correction in the camber. Thanks on the compliments. |
rsworksTc
Here are some low meg shots of her just hours after her make over at work will have better photos this weekend when I shine her up.![]() ![]() ![]() |
scrap
Very nice ride................. |
rsworksTc
Here are high quality shots![]() ![]() ![]() ![]() ![]() |
DTRUONG_112
love the setup man. Did you get spacers too or no? |
rsworksTc
Thanks, No the 35mm offset and being 8.5 inches wide sets them out flush with the fender lip. |
papi33614
NICE!!!!!!! ME LIKE VERY MUCHO |
tikbhoy
props on the car looks good and clean. did u get an alignment for before and after ? do u hear any rubbing ? did u had to modify ur fenders ? BCP power ! |
rsworksTc
I got an alingment when I dropped the car. I used the hotchkis rear camber links and the H&R front camber bolts. I have -.5 degrees of camber front and rear. I do have some scrapping not rubbing on large bumps. I fixed most of the issue check this link I explain how to fix the issue. Cleanance Issues fix |
tikbhoy
what is the stock camber for front or rear ? ( i dint use any means of searching =p ) |
rsworksTc
-.5 degrees front and rear. The range goes +- .5 degrees. |
guitarguru44
man i really thought that the cherry color would be gay but those rims are perfect. its cool too that not so many people have that color... keep it up |
