| stop sign show off |
| Car shakes when at full stop |
Keaole
ok im installing my progress springs and i was following rrimportracers guide, never saw that you had to cut the bump stop until i moved to where i had to do the front spring. Will it be fine or do i have to go back and cut it? |
You only need to cut the rear stops with stechs ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
Keaole
so im good then? it will be fine? its 1.8" on progress springs i believe |
Your fine with that drop no need to cut it... 2008 G37 OB Sport 6MT... 2007 335I 4DR... |
thekevin
cutting the bumpstops is recommended but not necessary. IMO, i'd cut the front bumpstops rather than the rear. 07 tC***92 SC400***92 Camry***91 300ZX TT for sale: fiveaxis sideskirts PM me |
If you're on stock struts/shocks, I would suggest leaving them alone. Cutting them with just springs runs the risk of bottoming out much harder than if there's a little more cushion. I bottomed my right front strut out with just Tanabe NF 210 springs a while back and when I went to install my TRD struts, I could see an imprint on the bottom of the bump stop plate (and a cracked bump stop) where the strut collapsed completely into it. If you go ahead and do struts as well, THEN I would cut them in half. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Keaole
Well, i got the rear ones done. My buddies and i are taking a break for tonight, i think i may just take it into a shop and have them finish up cuz my next 3-4 days are jam packed with stuff to do. Thanks for the help btw. It took us 4 hours to do the rears and god i have never seen so much random sh!t that we ran into lol. |
