Home > Visual / Audio Mods > Audio FAQ/Help > problem with amp
problem with amp
Dat_Tc_Guy
Charlotte
North Carolina, US
ok so i had an old amp in and everything worked fine. i got a new amp, plugged everything up and theres no sound from the subs. i think the amp has power because there is a light that surrounds the brand logo on the amp. but theres also an led for the power and an led for some other thing that says pro. niether one is on. what could be the problem guys?
[#] Sep 21, 2008 04:02pm
Manhattan Beach
Check your ground or your remote 12v wire
[#] Sep 21, 2008 04:04pm
Dat_Tc_Guy
Charlotte
North Carolina, US
but if the ground was bad, would the amp get any type of power?
[#] Sep 21, 2008 04:13pm
Dat_Tc_Guy
Charlotte
North Carolina, US
and just wadnering, if it were my 12v remote wire, what could have possibly happened?
KansasCitytC05
Platte City
Missouri, US
I would check the remote wire if it is lighting up that means it has ground so it should be your remote wire or your rca jacks.
tC Pimpin!!!!!!!!!
[#] Sep 21, 2008 04:32pm
colt4204life
Fredericksburg
RCA's could be in the wrong spot, maybe you got em' in the out ports??
Can't be ground or you wouldn't have power.
Most amps (or at least mine and a few i've worked with) won't light up if the remote isn't hooked up.
Yea I'm here to -> myspace.com/colt4204life
[#] Sep 21, 2008 05:05pm
armygirl718
PM scionara05tc sound systems and all types of electronics are his life and he knows every little thing about them. he can definately help you out
[#] Sep 21, 2008 11:11pm
Rezinetc
Hollywood
this might sound ridiculous but check if your subs are pluged in inside the box...ive seen countless people go through amps without even thinking about the subs being plugged in..
[#] Sep 21, 2008 11:16pm
NewJersey
Kendall Park
just follow all the wires and make sure the ground wire is grounded, the 12v wire is good and all the rca's are fine... but the rca's wouldnt prevent it from powering up.. you may also want to check ur fuses in the amp...
[#] Sep 21, 2008 11:22pm
Dat_Tc_Guy
Charlotte
North Carolina, US
ok problem was solved yesterday after i posted the question. i just didnt have time to reply. it was my ground. it was just loose so the connection was there but poor. but thanks everyone!!
[#] Sep 22, 2008 12:00pm
TOP: Home > Visual / Audio Mods > Audio FAQ/Help > problem with amp
