TWM-Performance
Hi Everyone,I wanted to stop by and make a couple quick announcements regarding our Scion tC short shifter.First, we now offer two separate models for the tC. Stage 1 is designed for those who would like to retain the stock knob height while still reducing the shift throw by approximately 25%. Stage 2 is the more aggressive model which has been on the market since the tC hit show rooms. It reduces knob height by 2.5- and shift throw by 35%.Both parts are currently available on our website and we have also activated the promotional code TCTWM for the month of June. By entering this code during the checkout process you will receive a 10% discount on our both tC shifters. Also, shipping is free within the continental US and Canada.Click here for more info.Thanks,Karel W.TWM
[#] Jun 01, 2005 01:57pm
GReddyTC
Carlsbad
New Mexico,
US
very nice to see you addressing customer suggestions!
[#] Jun 01, 2005 10:50pm
rsworksTc
I just ordered the stage 2 with the 35% reductions in throw for 112 including shipping with the discount going on right now. That is the best price I have seen.TCM I have one question is the one I ordered it said 2.5-/35% Reduction. I understand the 35% but what does the 2.5- vs the other .5- does that me it is 2.5 inches shorter than original.
[#] Jun 07, 2005 04:19pm
TWM-Performance
The 35% throw reduction indicates how much shorter the distance your hand moves between gears, while the 2.5- refers to the knob height reduction. In addition to altering the pivot points resulting in a smaller angle between shifts, the knob height is also reduced by 2.5- on the stage 2 for a sportier look and feel than the stock part.Check out both models at: http://www.twmperformance...sciontcshortshifters.htmI hope this helps.KevinTWM Performance
[#] Jun 07, 2005 05:04pm
tChillin
I just installed a TRD short shift kit. It changes the whole cage which they moved up on spacers to accomadate a shorter shaft, but retain the stock height minus a quarter inch. The advertised reduction in throw is 20%, I dont notice to much difference in the throws but the whole shift pattern seems much more accurate/less slop. I want to know if either of these TWM kits will work with the new TRD cage and what the effective change would be. Any idea if they would work on this?
[#] Jun 08, 2005 12:28pm
TWM-Performance
tChillin: I would recommend using the TWM stage 2 shifter with the TRD short shifter plastic assembly since they are compatible. Since TRD actually raises the assembly slightly, the TWM stage 1 may actually end up being slightly taller than stock. I-m sure that you will notice a massive improvement over the TRD short shifter by installing the TWM stage 2 short shifter. The throw reduction will be 35% as opposed to TRD-s 20%, along with a lower knob height for a much sportier look. They-re available here: http://www.twmperformance...ontcshortshifters.htmHope this answers your questions,KevinTWM Performance
[#] Jun 08, 2005 05:12pm
tChillin
I don-t suppose you would guarantee that would you Seriously though, has one been test in that configuration or at least looked at by your design/engineers ? I really dont want to buy it, try it, and it not work. But Im not entirely against it.... Thank for the info.
[#] Jun 08, 2005 05:57pm
TWM-Performance
- -tChillin- wrote:
- I don-t suppose you would guarantee that would you
Seriously though, has one been test in that configuration or at least looked at by your design/engineers ? I really dont want to buy it, try it, and it not work. But Im not entirely against it.... Thank for the info. Based on our experiences with other TRD shift assemblies in the Celica and Corolla we believe that the tC TRD assembly would work perfectly with our shifter. We-ve yet to see a TRD shift assembly which doesn-t house a shifter that has the same critical dimensions as the stock part (in other words, one which the stock part or our part wouldn-t fit into).Drop us an e-mail or give us a call anytime if you have any further questions or would like to order.Thanks!KarelTWM Performance1-888-569-8963
[#] Jun 09, 2005 10:07am
BugginOuT
Question: Is there a reason why the knobs that comes with the Performance Package are so expensive?
[#] Jun 09, 2005 12:24pm
rsworksTc
What is the threading on the stage 1. I just ordered on and want to know if my OBX knob will work? I believe it is 12mm standard thread.
[#] Jun 09, 2005 12:49pm
TWM-Performance
rsworksTc: The threads on both the stage 1 and stage 2 TWM shifter are M12x1.25, the same as the stock shifter. Speaking of knobs, we-re releasing several new designs in the coming months, check them out here: www.twmshiftknobs.com.Thanks,KevinTWM Performance
[#] Jun 09, 2005 04:41pm
guitarguru44
South River
New Jersey,
US
those are pretty nice short shifters and at a good price, may have to buy once I can gather a hundred twenty
[#] Jun 09, 2005 05:56pm
DOWNSHIFT
So Karel let me get this straight.Stage 1 = A higher shift (by 0.5) 40% throw reductionStage 2 = A lower shift (by 0.5 and a sportier look) but only 30% throw reduction <--- confused
[#] Jun 20, 2005 11:55pm
TWM-Performance
- -DOWNSHIFT- wrote:
- So Karel let me get this straight.Stage 1 = A higher shift (by 0.5) 40% throw reductionStage 2 = A lower shift (by 0.5 and a sportier look) but only 30% throw reduction <--- confused
 Here-s the break down, sorry for the confusion Stage 1 = .5- shorter than the stock shifter, 25% shorter throw than the stock shifterStage 2 (which is the one that has been on the market for a year) = 2.5- shorter than the stock shifter, 35% shorter throw than the stock shifterI hope this clears things up, the stage 1 kit is designed for people who are comfortable with the height of the stock shifter but would like shorter throws, stage 2 is for those who feel the stock shifter is too tall and crave a greater reduction in throw.Thanks,KarelTWM Performance
[#] Jun 21, 2005 09:46am
scrap
I am glad I have the stage 2 I would have been pissed off if I had the stage one. Thanks for the options TWM !!!
[#] Jun 21, 2005 10:53am
DOWNSHIFT
 Here-s the break down, sorry for the confusion Stage 1 = .5- shorter than the stock shifter, 25% shorter throw than the stock shifterStage 2 (which is the one that has been on the market for a year) = 2.5- shorter than the stock shifter, 35% shorter throw than the stock shifterI hope this clears things up, the stage 1 kit is designed for people who are comfortable with the height of the stock shifter but would like shorter throws, stage 2 is for those who feel the stock shifter is too tall and crave a greater reduction in throw.Thanks,KarelTWM Performance thanks for clearing that up karel.Im ordering one as we speak I also see that the throw % have changed ahhhh $114 or so broker
[#] Jun 21, 2005 09:15pm
TWM-Performance
Great! Be sure to let me know how you like it!For everyone else, there-s still one week left for the 10% discount so take advantage while you can. Just enter TCTWM in the promo code box during your checkout.Cheers,Karel W.TWM Performance
[#] Jun 23, 2005 10:42am
scrap
I love my TWM I had it in my TC since January, and it has been my best up grade so far. Don -t get cheap and just buy the ss get the weighted knob also.
[#] Jun 23, 2005 10:46am
DOWNSHIFT
- Great! Be sure to let me know how you like it!Cheers,Karel W.TWM Performance
coughcoughFREEBIEScoughcough
[#] Jun 23, 2005 11:41pm
