Home > User Content > DIY / Install Guides > DIY: LED vent install
silvrscion08
Davenport
I was inspired by hvtopiwala. I know there was a DIY vent install. But it wasn't to clear for me and probably for some others to understand I have made an updated one.
Parts Needed:
Led's
Wire connectors
T-Clamps
Female wire connectors
Male wire connectors
Eyelets to connect to Battery
Black wire
Red Wire
Electrical tape
Switch
You need to pop out all your vents,
I drilled a hole big enough for all the wire to fit down in the hole
Left side:
Right Side:
And Middle: (on the water fall itself)
I put 2 Led's in each vent like hvtopiwala cause I like lights.
Then you need to lower your glove box by pushing in on this tab, there is one on the other side press together and the glove box will lower.
All the prep work is done. Now time for the wiring.
Start with the passenger side first, wire the red to the red and black to the black using the connectors. After crimping wrap all connectors with electrical tape.
Then you can run the wire through behind the glove box through this hole.
Then I connected the female and male connectors so if I need to take off the water fall I can. One side is coming off of the LED's and the other off of the T-Taps.
There is another hole to run the wire through to go behind your speedo cluster and down to where you need to hook up the switches.
Then connect your last two LED's to the black wire and run to the neg. side of the battery.
Then connect all your lights to a female connector and attach to the middle of the two prong switch. And connect the battery to the end prong of the switch.
And finished product.
You don't need luxury, buy a Spec!
[#] Sep 14, 2008 01:25pm
Kurisutaira
hey u finally got it up good write up. LOL?! did u write this on the PS3? if so u have way more patience then me...
[#] Sep 14, 2008 01:31pm
silvrscion08
Davenport
Roomies laptop.
[#] Sep 14, 2008 01:32pm
07BsptC
Lake Charles
Louisiana, US
nice install dude
-PitchBlackTc07
[#] Sep 14, 2008 01:35pm
LiLee
Lowell
Massachusetts, US
ouu that looks nice!
Random of the day: i feel sick. :[
[#] Sep 14, 2008 05:01pm
BlueFin
Nice work man! Good to see you got'em in! I like how that red looks
I just did my side AC vents this week. I ended up putting three in each one; plus three in my cupholders.
[#] Sep 14, 2008 05:51pm
silvrscion08
Davenport
Sweeeet... My first sticky
[#] Sep 14, 2008 10:40pm
It's a very nice DIY so it's going to stay around for others to use.
[#] Sep 14, 2008 10:41pm
Kurisutaira
lol dont tell yr girl that. im sure she wuld get jealous :-p
silvrscion08
Davenport
^^^ lmao
[#] Sep 14, 2008 11:56pm
TOP: Home > User Content > DIY / Install Guides > DIY: LED vent install
