Home > Performance Mods > Suspension & Brakes > Car shakes when at full stop
Pages: 1 2 >>
Take4roll10
My car is a 2005 and has 23,500 miles. I've recently replaced the front brakes, had a wheel alignment and tire balance.
I got an axle back exhaust installed 3 weeks ago and ever since then I noticed that whenever I'm at a complete stop, on my brakes, in drive or reverse, my whole car shakes. I can definitely feel it in the steering wheel. When I put my car in park or neutral, it stops.
Any ideas what this could be?
[#] Sep 05, 2008 10:31am
tCdreamer87
New York
dam we must be the only 2 people with an 05 that have that lil bit of miles on our cars, i have like 200 less then you
Life is hard!!
just sit back let go and let god deal with it!!
[#] Sep 05, 2008 10:34am
New Brunswick
Mine does that - I think it's the transmission.
220+ WHP - 14.044 @ 97.02 MPH
Auburn
Alabama, US
Do your RPMs fluctuate when you notice this happening?
[#] Sep 05, 2008 10:36am
Take4roll10
the transmission? what could be wrong with the transmission?
Take4roll10
I didn't notice it fluctuating. Ill have to double check after work.
[#] Sep 05, 2008 10:38am
Auburn
Alabama, US
There is a small chance of the axle-back causing this vibration if it's hitting the bumper or other part of the car.
Aftermarket exhaust does cause a little more vibration compared to the stock exhaust.
not really sure, but just a couple of things to look at.
[#] Sep 05, 2008 10:41am
New Brunswick
Nothing's wrong with it - but if you're at a stop in gear, there's still some throttle pushing you and the transmisison is spinning while the brake is holding you - it'll vibrate and with the crappy motor mounts in our cars, it'll shake the car a little bit more. It's no big deal. You may want to check the transmission fluid though - might need to do a flush.
[#] Sep 05, 2008 10:42am
Take4roll10
ill check that out, but would the axle back cause the steering wheel to vibrate?
Someone was telling me it could be the rotors
[#] Sep 05, 2008 10:45am
tc2c
Its def not her transmission
[#] Sep 05, 2008 10:47am
New Brunswick
Nope - it's the engine and transmission. If it stops when you shift into neutral or park, it's the tranny. I'm pretty sure it's normal.
Auburn
Alabama, US
it can be rotors when you are in motion, but from what you are saying, you notice this when holding the brakes at a stop.
It sounds like you are having a really super rough idle which could be the transmission as Nick said, but with your miles, it's not likely. It might be a fuel/timing related issue.
Wouldn't hurt to have a shop take a look.
[#] Sep 05, 2008 10:48am
tc2c
It is not the tranny because the tranny went on my tC and I would know what it feels like if it was the tranny and it is def not that.
[#] Sep 05, 2008 10:49am
Perry Hall
  • $upervillain
The axleback could cause vibration, but it would not cause the steering wheel to shake. Krdshrk may be right about the tranny mounts. It could also be your rotors, but if you just had brakes done, then they would have replaced the rotors if they were at the point where you could feel them.
[#] Sep 05, 2008 10:50am
New Brunswick
Why would it be the rotors? She's at a complete stop and there's no movement in them...
Blown tranny is another thing - remember I went through it, Amanda!
[#] Sep 05, 2008 10:51am
Take4roll10
they didn't change the rotors
tc2c
Yes I know I know but I drove it the other night and I know its not the tranny. I also had this problem in my Saturn and it was the rotors. Im sure its not so bad she just needs to bring it to a shop ASAP!!!!!
[#] Sep 05, 2008 10:53am
New Brunswick
If it's shaking when she's BRAKING then it's the rotors that need to be resurfaced. She's saying it's at FULL stop though. The wheels and rotors aren't moving so they can't cause any vibration if the car's STOPPED!
It's gotta be the transmission and transmission mounts.
[#] Sep 05, 2008 10:56am
Zerinephalis
Nashville
Tennessee, US
It's not the rotars. Think about it you only feel it when you're at a complete stop and the rotars would only make a difference if you felt it when moving too.
Live fast, drive faster.
[#] Sep 05, 2008 10:57am
Take4roll10
ill get everything checked out just to be sure.
I can't imagine something being wrong with my transmission.
[#] Sep 05, 2008 11:00am
New Brunswick
It's nothing that's wrong with the transmission... I'm fairly sure it's just the transmission/motor mounts. They will wear down after time.
[#] Sep 05, 2008 11:02am
tc2c
maybe she needs some tranny fluids!!!!! Oh and Randi u need some steering fluid.
[#] Sep 05, 2008 11:04am
Auburn
Alabama, US
I did mention in the my previous post, it is not the rotors.
Bad mounts can cause the vibration, yet again with your low miles, it's not likely.
There may be a fuel issue which would cause the rough idle (example: water in the tank)
edit
seeing the above post, low power steering fluid or a bad power steering pump would also cause the same issue.
New Brunswick
I think most of those miles are city driving too so that can't help. But yes it could be fuel or tranny fluid too. You SHOULD flush after 30k miles...
[#] Sep 05, 2008 11:07am
Take4roll10
edit
how could water get in the tank? cuz when i installed my front strut bar, I didn't put that black piece (where the wind shield whipers are ) back properly and there was a little gap between that and the windshield, but only by the drivers side. The side where the engine is was fine....do u think water could have damaged something over there?
[#] Sep 05, 2008 11:09am
Pages: 1 2 >>
TOP: Home > Performance Mods > Suspension & Brakes > Car shakes when at full stop
