Home > Performance Mods > Intakes > Idle revving
Idle revving
Bam1779
Encinitas
After i installed my injen CAI when my car is in neutral it revs from 1k RPMs to 1.5K RPMs then back down then back up and so on. is this normal? any idea what is going on?
[#] Sep 04, 2008 08:39pm
Does it just do this upon cold start up for about 2-3 minutes? If so, that's normal. That's a "heat cycle" the engine is going through to heat up the block.
If it keeps doing that all the time, that's not normal and you may have a vacuum leak.
[#] Sep 04, 2008 08:40pm
Bam1779
Encinitas
hmmm ill have to look for it after i am driving for a little bit, but thanks for the help
[#] Sep 04, 2008 10:24pm
java09
Honolulu
Hawaii, US
i agree with web.. vac leak..
2008 Turbo Scion tCizzle
POWERED BY TURBOTOYOTAS!
310WHP, 272WTQ
more to come_..
[#] Sep 04, 2008 10:35pm
TOP: Home > Performance Mods > Intakes > Idle revving
