| TRD Spring Install Cost |
| Review: TRD SPRINGS!!! |
| Looking for some TRD's springs |
| TRD suspension |
| TRD Emblem |
Zerinephalis
The previous owner of my car put TRD springs on it. I don't know everything there is to know about suspension so I was just wondering if TRD was a good product and if I need to put new struts on now that he put the springs or if I'm good to go as it is. Live fast, drive faster. |
Beckaz_tC
Your good to go. TRD is made by Toyota so it is of good quailty. TRD = Toyota Racing Development. Also the TRD springs will not void your warranty if anything ever happens. |
twiztidtC
I'm having the TRD springs installed tomorrow in my car. I purchased them because A) They are a Toyota product and wouldn't void the warrenty and B) they offered the smallest drop I could find. I'm sure you'll like the springs, nice they were already installed for you! ![]() Livin' Loud & Addicted to Bass http://cardomain.com/ride/3086512 |
VIP_tC08
I also have TRD's..very clean and sexy drop..you will be good ![]() '08 // Flint Mica // tC |
h2oyelnats
yayy for toyota products lol. how much did you guys drop it by? |
I have TRD springs and I have no complaints. They perform well with the stock shocks and are ideal for everyday street driving. |
wuma
I think the TRD drop is 1.3" all around. Looks nice after they settle. |
h2oyelnats
oo any tire scratching/scraping? |
nope, even tC's dropped down to 2.5 inches do not scrape tires. |
All depends on your suspension setup along with camber and toe correction.....also your rim offset. ![]() Complaining is futile when you supported the victory. |
Zerinephalis
I read the change was so insignificant I wouldn't need camber bolts. This sound right to you? Live fast, drive faster. |
Dr_Isotope
Your camber angles on a TRD drop will be within spec. Just have your toe corrected and call it a day. ![]() Custom parts for your Scion tC: Doctor Isotope dot Com |
^Yup. I'm on TRD shocks/struts with Tanabe NF 210 springs with an overall flat drop of 1.7" My camber was adjusted to .8 on the driver's and .6 on the passenger side (with stock camber adjustment) and the toe was corrected. Tires are still wearing nice and flat with no outer or inner edge wear. You'll be fine, as stated, on TRD. ![]() Complaining is futile when you supported the victory. |
h2oyelnats
<<< still a noob what's the camber and toe? |
FYI, though TRD may be a part of Toyota.. most of its products.. are NOT made by them, but more products from other companies licensed under the TRD name. (i.e. the TRD LSD is made by Quaife and was sold back then under Quaife's name until TRD acquired the license to sell them under their name.) LED Swaps and parts available! PM me for details, questions and/or quotes. There's Strong, and then there's RETARD Strong. Decelerate your life. The Few, the Proud... (they never really tell you what they're really "proud" of, eh?) Below All (USAF - Uncle Sam's Academic Failures) |
Camber is the inwards or outwards tilt of the tire from the top. Toe is the left (outer) or right (inner) turn of the tire. Camber tilts the inner edge of the tire at a certain angle. Toe will turn the bottom of the tire out or in. The tire will rotate and if toed out, it will cross cut the tread from the inside edge to the center. If toed in, it will cross cut the tread from the outer edge to the center. You want to have a nice, flat toe but camber can be negative. Negative camber will help on cornering b/c the weight of the car will push to one side and force the tire to flatten a bit. With a negative camber, it will tilt to a flat tread. The toe, being straight, will help the tire travel straight and not cross cut the tread. Here's a thread with some details and some pics: http://www.ozebiz.com.au/racetech/theory/align.html ![]() Complaining is futile when you supported the victory. |
