Home > Performance Mods > Transmission / Drivetrain > Changing ATF transmission fluid?
istcioni
My car has about 32k miles and i think its time for a change..looks dirty..has any one done it before, tips? thanks
[#] Aug 24, 2008 05:01am
JBoy510
Hayward
yup, changed mine with redline mt90 synthetic fluid. just drain it out, remove the reverse light sensor in the engine bay to pour in the new fluid. keep the top bolt on the tranny open, its to make sure its not overfilled. use a long funnel too, its kinda hard to do it with a shorter one. there should be a diy on it so look through the section. im pretty sure that it would work for the auto (i think)
[#] Aug 24, 2008 05:12am
  • El Chupacabra
Nope, the process is different for manuals... I don't think anyone's done a DIY for an ATF change :o
The Thread Killah
[#] Aug 24, 2008 05:22am
carcandy
Detroit
Michigan, US
  • Silver Sponsor
ATF is easy; I have done it many times. Get your self a nice filter to replace your old one. Drain the oil using the drain plug on the pan and then unbolt the trans pan. Remove bolts holding down the filter, replace filter and follow the reverse procedures. Filter kit comes with a new pan gasket an do-ring for the filter. Add some nice ENEOS transmission fluid. ENEOS in stock ready to ship.
Greg
[#] Aug 24, 2008 07:18am
32,000 miles and you want to change the AT fluid? You don't need to.
You should look into this when you're closer to 100,000 miles.
[#] Aug 24, 2008 04:09pm
TOP: Home > Performance Mods > Transmission / Drivetrain > Changing ATF transmission fluid?
