Home > Performance Mods > Transmission / Drivetrain > clutch replacment???
log11
Milwaukee
Wisconsin, US
Hey everybody my clutch us gettin to its end, still will chirp is gears while shifting, but its pretty worn down, iv never replaced one before.
So is it possible to replace it yourself? and if so how hard is it really?
and since i didnt blow my clutch, is buying a new clutch the way to go, or is there any to do to fix the problem since its not gone yet? i dont know enough about clutch and stick shift so if anyone has advice let me know please thanks!
[#] Aug 15, 2008 01:23am
danyo
Los Angeles
http://www.scionlife.com/...highlight=scion++sway+bar
this is wat u need to know. it's a pretty lengthy process. requires a good amount of tools.
[#] Sep 04, 2008 01:20am
xcessivenoize
San Bernardino
^^x2 i can be done, but you need the right tools (pref air tools if ya got them or its gonna be a long day) and you need to know what your doin, you may have to drop the sub frame to move the tranny out far enough to get inside. dont know if there is enough room to slide it over in the car
[#] Sep 04, 2008 01:24am
danyo
Los Angeles
yeah.. i'd definitely recommend finding more info on it because i can already tell the guide doesnt explain everything but it's a START!
[#] Sep 04, 2008 01:38am
clutch discs are wear and tear items. There's no fixing, just replacing.
When you replace it, you need to replace the clutch disc, pressure plate and throw out bearing. The flywheel may still be ok but it's recommended to get it refinished (resurfaced) or replace IT as well.
[#] Sep 04, 2008 08:22am
If you go with an aftermarket clutch, be sure and get one that isn't overkill.
If you're going to do this, (just as I did) you may as well put in a lighter flywheel too.
[#] Sep 04, 2008 09:42am
TOP: Home > Performance Mods > Transmission / Drivetrain > clutch replacment???
