Home > Performance Mods > Intakes > Factory Intake mod.
Factory Intake mod.
Toyota-Scion
Kansas, US
Ive read so much about removing a pipe which makes the stock intake sound a little bit better...
my question iss..
is there a sticky or DIY for this...
and what are the pros and cons???
[#] Aug 07, 2008 08:31pm
tCdreamer87
New York
if u are talking about taking off the second canister after the MAFS dont do it. your car wont start up and then it wont hold its idle if it starts. u would idle at like 200 rpm and dies rite away
Life is hard!! deal with it how ever you can! you do what you can and thats the bottom line.
[#] Aug 07, 2008 08:38pm
caldwell246
I've heard of removing a silencer in a stock intake to make it sound a little better. I couldn't find any good DIYs on it, but it probably is not worth it. If you are just looking for a cheap solution to make your car sound louder you can buy cheap tubing on ebay and a cheap cone at WalMart and make your own short ram intake. The only problem is getting the MAS to work with it. Better off saving a few bucks and getting an intake from companies like K&N and Ingen.
[#] Aug 12, 2008 12:14am
Blckdouttc
Trumbull
Connecticut, US
the one that goes into the bumper after the box can be removed. just look to where it goes its 1 huge plastic screw. sure its louder but you have a huge empty hole going into ur air box. if u want volume, get an ebay short ram
2006 BSP tC
[#] Aug 12, 2008 12:22am
Not sure where you got this information but a few users on this site have the silencer removed with absolutely no issues. It does not effect MAF sensor readings (since it's after the sensor anyways) and only closes off a dead air section in the intake.
It's safe to remove the silencer.
[#] Aug 12, 2008 12:31am
TOP: Home > Performance Mods > Intakes > Factory Intake mod.
