| Tire Pressure Warning Light |
| Tire Question.... |
| are these good tires? |
| Going to Miami! |
| Tire rotting... |
keys101
well ever since i got my new rims on the tire pressure warning light came on and i cant seem to fix it and the pressure is good?? |
You have an '07. Are your new wheels TPMS compatable? Has the TPMS been moved over to the new wheels? ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
rimjay
Reg'd: Jun 01, 2006 Godlike Advisor |
guessin ur an 07+...theres a tire pressure monitering system in the newer ones, u have to take them off your stock tires and put them on ur new tires, or else the light will stay on i dont think theres a fix for that yet, some1 correct me if im wrong |
Yup, if the TPM sensors have not been swapped (as they should have), then you will not be able to make that light go out and your tire monitoring system will not function. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
RouletteTc
Reg'd: Jul 06, 2007 Scion Guru |
My mechanic swapped the TPMS for me into my new rims. Hopefully, whoever mounted your rims and tires was smart enough to do that. ![]() -Thanks for the sig Aciidsneaker |
dannn4au
Reg'd: Jul 26, 2007 Tire Changer |
I had that same problem what you gotta do is press and hold the tire pressure button in the glove box for like 15-20 seconds. First the light will go off, keep holding it and it will flash 4 or 5 times and once it stops flashing let go and you should be good. If that doesnt do it idk what to tell you. |
It works for you because you've got an '05. '05-06 had simple rotational-speed based TPMS. The '07's have a true TPMS so that won't work. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Doesn't work that way for 07+. They have in-tire TPM sensors that must be switched to the new wheels and then reset. If they are not there, it can't be reset. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
CadenceScion
Reg'd: May 27, 2008 Oil Changer |
I have the same problem w/ my aftermarket rims too. The only thing I know that fixes that, is either proper air pressure, or having the rims rebalanced. The computer is set up to run the OEM rims which on most tC's is 17's, or 18's if you have an RS1 3.0. I haven't had my rims rebalanced yet, but I know mine came off of an 01 Stratus. I will let you all know if I get the issue corrected. |
RS1 3.0? You mean RS 3.0.... The RS 3.0 doesn't have special wheels. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Kurisutaira
step 1check and make sure that your tires are inflated to the correct pressure step 2turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (in the glove box) until the warning light turns off and then release the switch. step 3now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times. step 4initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed. "This is what happens when an unstoppable force meets an unmovable object" |
^Before any of that, he has to make sure they even put the sensors in the new rims or none of that will matter. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
BlazednSleepy
Reg'd: Sep 30, 2007 Chief Mechanic |
hmmmmmm..I never knew about that tire sensor thing..when i had a buddy of mine get me rims and tires to install them i got the car back with no problem or tire pressure light..and i have 07..so does this mean they did it correctly???? |
Yes. They put the TPM sensors in the new rims. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
BlazednSleepy
sweeeeet.. thanks man |
keys101
well my old rims are a couple states away so i wont be able to do it for a whiule but it wont hurt anything will it, and where are the sensors located, oo and yes i have an 07.. |
No, won't hurt anything...just won't have the monitoring system functioning. They are built into the valve stem itself. They probably just put a generic stem in place of it if they didn't take it out. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
JRod_TC
Reg'd: Apr 18, 2008 Master Mechanic |
hey guys .. 05 dont have tire sensors .. do they? |
No, 05-06 have rotational sensors built into the axle. We are fine ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
Not a true TPMS in the valve stems. The '05-06 tC has a rotational speed based TPMS. So if 1 tire gets low on air, it's gonna start spinning faster and then it'll set off the TPMS. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
keys101
can i just order some and have them put in??? |
Yes but they're not cheap. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
Here's what you can do. I know this worked for the people i suggested it to. Just get one TMPS sensor and put it in a sealed tube and pump that tube to 32psi and reset your TMPS. Then just keep that tube in the car and you'll be golden. Just remember you check your tires every so often to make sure they have enough pressure. ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
Heh that's a good idea... but it kinda defeats the purpose. Oh well. If your rims aren't TPMS compatable, I'd do that. If they are compatable though, get those put on. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
CadenceScion
Sorry what I ment to say was the Scion tC RS 3.0 comes w/ 18'' rims, not 17''s. |
