Home > Performance Mods > Exhaust > nasty rattling noise!
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
not sure if this goes here.
so im gettin this god awful rattling noise when i shift from 1 1/2 k to 2 1/2k. any tyme im in between that range that noise is going on. im thinkin something is not right with my exhaust like something is loose but not to sure. has this happened to anyone else or has heard of this? im started to get pissed listen to that crap. and im gettin ugly looks from ppl when im drivin.
[#] Jul 23, 2008 09:33am
Reg'd: Dec 08, 2005
I noticed you have an Injen Cold Air Intake, do you think it might be rattling against the fender perhaps?
[#] Jul 23, 2008 09:35am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
naw its not that, i know what that sound sounds like.
[#] Jul 23, 2008 09:38am
Reg'd: Sep 29, 2007
Which exhaust do you have? It could possibly be the thin metal heat shield underneath the car rattling against the exhaust.
220+ WHP - 14.044 @ 97.02 MPH
[#] Jul 23, 2008 09:41am
Reg'd: Oct 21, 2005
$upervillain
You may be right about the exhaust. Shifting that low in the gear range will make your engine stutter a bit, and the midpipe or axleback may be coming inot contact with the heat shielding under the car. Get under the car and see if there are any spots where it looks close enough to hit and see if the area looks fresh from rubbing (not covered in dirt, etc)
Even Zombies can Search...
[#] Jul 23, 2008 09:44am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
i have the megan drift spec.
well my buddie has a ksudo exhaust and his is do the same thing but only just when he revs the car up. when he's drivin or shiftin no sound unlike mine. he removed his heat sheild aswell.
[#] Jul 23, 2008 09:47am
Aviator213
Reg'd: Apr 07, 2007
no need to remove the heatshield, its there for a reason lol taking it away may not be the best decision.
When you get the chance to get underneath the car check all the connection points and see if a bolt is rubbing against the shield.
[#] Jul 23, 2008 09:52am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
ill prolly get under there today or tomarrow. but what id the bolt is rubbin the heat sheild? get another bolt or remove the heat sheild?
[#] Jul 23, 2008 10:11am
Reg'd: Sep 29, 2007
Bend the shield (it's aluminum or tin or something) and get a rubber piece or something to cover the bolt.
[#] Jul 23, 2008 10:14am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
alrah sounds like a got a mission lol.
[#] Jul 23, 2008 10:24am
Reg'd: Oct 21, 2005
$upervillain
You can also just hit the shield with a hammer to "finesse" it into the proper shape. Its just a heat shield. Its easier to change its shape then the shape of your exhaust.
[#] Jul 23, 2008 11:37am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
alrah sounds good. ill give it a shot today or tomarrow.
[#] Jul 23, 2008 11:44am
da_grouch
Reg'd: Apr 18, 2008
Master Mechanic
well i finaly got under the car today and it wasnt the heat shield, it was where the s-pipe and mid pipe connect. one of the bolts were snaped in half! ionno how the hell that shit happened but i replaced both bolt and made sure that ish was tighted like no bodies business haha! so i was runnin with an exhaust leak and that nasty rattling noise for god knows how long!
[#] Jul 26, 2008 12:01am
TOP: Home > Performance Mods > Exhaust > nasty rattling noise!
